help with broken axle/cv
well, i think i broke either an axle or cv joint today, and i need some help figuring out what the problem is. whenever i accelerate, the car vibrates/shudders like holy hell, but is perfectly smooth when coasting. the car still accerlates fine, and the problem isn't really noticable when first moving from a stop.
There is no clicking while turning or decelerating like i've seen with bad cv joints, so i'm thinking it's an axle. Also, i see no tears/leaks in the boot.
Anyway, if it is a broken axle like i think it is, how do i tell which one it is. the only suggestion i've gotten is to go and dump the clutch to see if i can COMPLETELY toast it, but for some reason that plan just doesn't seem like a good idea.
Any help is appreciated, thanks guys!
You have screwed the inner joint in your axle. Mine did the same thing and I decided to replace it, now the stupid axle wont seal. Time to replace it. Good luck..
Blaze
Blaze
will driving on it a little further make it any worse? i'm not at a place where i could fix it, plus i have NO tools what so ever. to get home, it's about a 45min drive.
i mean, nothing's gonna fall out or nothing right?
taimysho0
Jul 8, 2009 01:29 PM
rhdekhatchie
Mar 16, 2008 10:17 PM
