Finally Dyno'd My new motor today!!!
Well finally hit the dyno with the new setup today... Was really happy with the numbers and smooth everything is now. My Downpipe is a 2" smashed/bent/destroyed/crushed POS that needs to be replaced ASAP as previously known, it made dynoing higher then 12psi impossible...
Final number's were...
@12psi on a mustang dyno
285whp@6750rpm
256tq@4500rpm
Dyno Video
Setup:
http://www.activeperf.com/memb...stare
These are on a mustang dyno, which reads lower then Dynojets..
Now I gotta get a real downpipe so I can turn the boost up and see what kind of high-end numbers I can get...
Thanks go out to Tom and the rest of the guys at Payn for the good work as usual...
Modified by Alstare at 5:19 PM 3/26/2004
Modified by Alstare at 2:51 AM 3/28/2004
285whp@6750rpm
256tq@4500rpm
Dyno Video
Setup:
my exhaust is 2.25 and i took my cat out and had a test pipe made and the stupid muffler place made me a 1.5 in test pipe so basically i have a 2.5 in down pipe then a 1.5 in test pipe and then 2.25 exhaust after the test pipe. i am going to get a new test pipe made of 2.25 to match the rest but i was wondering is that 1.5 in test pipe one of the reasons that is causing my slow spool time as well as hard to make high boost?
Thanks guys...
Yeah I knew my DP sucked but just one of those deals where 90000 other half projects on the go so I wanted to get the tuning done so I could wrap up alot of stuff, and worry about making big number after...
I think the 89mm pistons bringing it to almost 2.4l helped with the tq alot. It's raining like mad all day here so I haven't really got to even try it out yet. And the weather for the rest of the week looks the same so we'll see.
It pull real good once it grabs though..heh
I don't have my logs pulled off my ems yet, but I'll check later to see where full boost was made. I remmeber it was alot lower then I had thought it would be though..
My website is down with my car pics and mod list and such, but when it comes back up I'll add it to this thread..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 »</TD></TR><TR><TD CLASS="quote">I thought the rev-limit of H22 was 8000,thats a good ways away.Did you stop making power or something.
Sweet numbers.</TD></TR></TABLE>
stock rev limit is at 7200 holmes scratch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir3n »</TD></TR><TR><TD CLASS="quote">7200 is redline, stock fuel cut is 8000 on an h22... holmes</TD></TR></TABLE>
thank you.I knew something was 8000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">nice numbers.. do you plan on hitting Milan this yr?? hope to see you out there..</TD></TR></TABLE>
Yeah Milan is the closest track for me... but it get's too damn busy...
But yeah I'll be out there sitting in line like every year..hah
See ya there man..
See ya there man..
BodyKits NW
Nov 11, 2004 11:54 AM
