si tranny rpms/mph
i picked up a si tranny and put it in my car this week along with a new exedy clutch. i finally got done today and went to drive it, but it doesnt pull like i thought it would. what rpms should i be turning in 5th gear at 70 mph? the car is doing 3400-3500 rpms at 70 in 5th. i think i may have gotten screwed and gotten a dx transmission! how many rpms should it be doing if its a si @ 70. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr »</TD></TR><TR><TD CLASS="quote">what size wheels and tires do you have for example....185/60/14</TD></TR></TABLE>
Doesn't really matter since the VSS is in the tranny. Wheel size only matters when you're dealing with actual ground speed, not the speed indicated by the gauge cluster.
When the speedo is reading 70mph, with an Si transmission the tach should be reading 3400 RPM and with a DX transmission it should be reading 3100 RPM.
You have an Si tranny.
You definitely have an Si tranny.
There isn't an insanely huge difference between the two; all the gear ratios are the same except for the final drive - the Si FD (4.25:1) is 9.5% shorter than the DX FD (3.88:1) so each gear should feel just a little quicker.
D-series transmissions really aren't short at all. The Si tranny is about equivalent to a B-series "LS" tranny in terms of gearing, which is crappy. The Si tranny is as good as you can get for a D-series though without resorting to hybrid gearing (i.e. ZC gears with an Si FD) or an aftermarket final drive (i.e. ATS 4.73:1).
Or you could just go B-series, have a shorter tranny AND more power.
well atleast i know that its really a Si, i thought it felt a little stronger but i also thought maybe it was the new clutch because my old one was ****! lol, but i think maybe i expected it to be geared like a b16 tranny or something. im just glad its really a Si tranny and i didnt get duped because its a pita to take out lol
thanks
thanks
I just bougt my 2nd si... I think when i'm going 70pmh I'm at like 3200-3300rpms....
how do i know if my tach is still accurate?..... it has like 213k on the car... could the cable vss be in accurate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">I just bougt my 2nd si... I think when i'm going 70pmh I'm at like 3200-3300rpms....
how do i know if my tach is still accurate?..... it has like 213k on the car... could the cable vss be in accurate?</TD></TR></TABLE>
WTF... dude i was testing it out yesterday and the tach was only at 3200rpm going 70mph.
this is a bone stock EF.... (14" steelies and regular tires)
how to check if i really do have asi o dx tranny? is there a code?
yea there is a casting number on the tranny near the passenger axle. its a small circle.. if i remember correctly my si reads pl3 over 3000, whereas on my dx the bottom number started with an "a". it may be that if your using a stock tach that it could be off 2-300 rpms.. im using aftermarket tach
Import_lifestyle
Sep 5, 2005 02:51 PM
1SickHb
11
Apr 1, 2004 06:06 AM
91hondacrx
Nov 29, 2003 09:13 AM
ViperRedCRX
Feb 13, 2003 01:50 PM
