HCP AC bracket with hasport mounts will it work???
Old Mar 26, 2004 | 09:04 AM
VAAJ's Avatar
Default HCP AC bracket with hasport mounts will it work???
anyone with hasport mounts ever try using the HCP ac bracket to obtain ac??? if it works then i'll rather buy the HCP bracket because the hasport bracket cost way too much $$$.
Old Mar 26, 2004 | 09:59 AM
MOTOCOMPO's Avatar
Default Re: HCP AC bracket with hasport mounts will it work??? (VAAJ)
It should. Don't see why there would be a problem.
Old Mar 26, 2004 | 04:35 PM
VAAJ's Avatar
Default Re: HCP AC bracket with hasport mounts will it work??? (EF0)
i'm concern because the hasport mount position the motor a little forward more then the HCP mounts. Anyone who has done this please confirm it so i can order the hcp bracket without worrying too much.
Old Mar 26, 2004 | 06:09 PM
VAAJ's Avatar
its going to be summer very soon.
Old Mar 26, 2004 | 06:14 PM
wtsexton's Avatar
It should work fine. But I have a hasport that I can cut a deal on for you.
Old Mar 26, 2004 | 06:32 PM
Jonathan_ED3's Avatar
I used HCP a/c bracket with Hasport mounts in my EG/H22. There was NO room at all. Took about 30 min just to get the compressor to line up, and when it did, it was sandwiched in there permanently. Just like on the EF/Bseries, Hasport puts the motor up closer to the radiator support with the H mounts.
Not to mention the vibration with the a/c on just plain sucked.
Why not go all HCP?
Old Mar 26, 2004 | 11:06 PM
VAAJ's Avatar
Default Re: (Jonathan_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">I used HCP a/c bracket with Hasport mounts in my EG/H22. There was NO room at all. Took about 30 min just to get the compressor to line up, and when it did, it was sandwiched in there permanently. Just like on the EF/Bseries, Hasport puts the motor up closer to the radiator support with the H mounts.
Why not go all HCP? </TD></TR></TABLE>
i would go all HCP, but then i have the hasport mounts already.
Old Mar 26, 2004 | 11:17 PM
Fobtions's Avatar
Default Re: (VAAJ)
i would think the hcp ac bracket would work better on the hasport mounts better than their own mounts. the hcp position the motor alot lower then the hasports, and the compressor comes really close to the crossmember.
crxdxsir
Jun 9, 2007 09:57 AM
Jesterian
Aug 18, 2006 01:26 AM
LSegHatchy
Aug 18, 2005 11:12 PM
trigga
Mar 17, 2005 10:41 AM
red civic standard
Apr 29, 2002 08:00 PM
