is it bad to remove this bracket???
this is really a newb question but i was wondering if its a bad thing to remove the ac mounting bracket that says p54 on it .... from the car completely... the one with the rubber mount on it ????
I really need to knwo cuz i just took the ac out and i took it off and i dunno if it should just put it back on or not ??? someone let me know thanks
Matt
Matt
Re: is it bad to remove this bracket??? (LSegHatchy)
You are referring to the ac mount right? yeah keep it on, if your worrying about a few lbs check out the aluminum type-r mount, I think you can get them from inline4
Re: is it bad to remove this bracket??? (dez6)
Do not remove unless you got aftermarket mounts, like hasport or something. Your engine will hop all over the place, you will break axles, and get alot of wheelhop.
Re: is it bad to remove this bracket??? (dohc_si)
welp im not sure what kinda mounts they are ... a friend gave them to me when he helped me with the swap a while back .... he got the ls for me as a bday gift .... so yeah ... ne ways ... im hopeing thing will go good with this car.......... also another question ... .. a bolt on my drivers side mount snapped in half how do i replace this ... ???
endless_pain
14
10-08-2022 10:48 AM
VAAJ
03-26-2004 11:17 PM
B19CivicHB
09-23-2002 09:46 AM
