RSX type r
Are any of you guys running the K series type r motor? If so how do you like it, what kind of numbers does it put down, and for what kind of price?
What is the K series R motor code?
quite a few of the guys on clubrsx.com have the K20A swapped in. Run a search in the NA and Performance sections of clubrsx and you'll find your answers.
More or less, they are running close to Type-R numbers since the RSX is a bit heavier and doesn't have a few compenents.
I'm running a K20A in my 2001 Civic, which I previously had a K20A2 in (Same setup as sig, but with TODA Spec A's w/o the TODA Header, Comptech instead). I don't have actual dyno numbers, but the engine itself does feel a little stronger, or maybe that's the TODA header..hehe..
I was able to get an entire DC5-R front clip for 4 thousand. It had everything except for the suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DallasTypeS »</TD></TR><TR><TD CLASS="quote">would you mind telling me where you got the whole front clip for $4000?</TD></TR></TABLE>
yes esp since a k20a normaly goes for about 5-6 thousand
there actually isn't really a RSX Type R... it's called the Honda Integra Type R over in japan and i don't think they make the type R in the US and the RSX is stilled called the integra in japan, and only in the US it's called the RSX
From: Derek Jeter drinks wine coolers,, The Nation, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelemi821 »</TD></TR><TR><TD CLASS="quote">there actually isn't really a RSX Type R... it's called the Honda Integra Type R over in japan and i don't think they make the type R in the US and the RSX is stilled called the integra in japan, and only in the US it's called the RSX</TD></TR></TABLE>
Great first post, bravo, your on your way to becoming a hall of fame HTer
how much was the motor??? and all you need was the ecu reflash right???
i want to do the same thing but i dont want the 6 speed tranny... i know the 5 speed will bolt up with no problems......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineRSX619 »</TD></TR><TR><TD CLASS="quote">how much was the motor??? and all you need was the ecu reflash right???
i want to do the same thing but i dont want the 6 speed tranny... i know the 5 speed will bolt up with no problems......</TD></TR></TABLE>
Won't it need the 6 speed? Would you lose the power running on a 5spd tranny?
As for the ECU, yes, just need to do a K20A reflash and some engines will come with the Type-R ECU.
Thanks buddy
As a new member let me be the first to say if you don't have anything to add to a conversation don't say anything. I said RSX so that people would not be confused between this motor and the C5
I have a question for anyone who has done the swap in to any car but more specifially in something other than an RSX or a new hatch, preferably an EG or an EK. What do you do with the trans. you end up with six gears? You just have to get custom axles, shift linkage, etc.?
Thanks buddy
As a new member let me be the first to say if you don't have anything to add to a conversation don't say anything. I said RSX so that people would not be confused between this motor and the C5I have a question for anyone who has done the swap in to any car but more specifially in something other than an RSX or a new hatch, preferably an EG or an EK. What do you do with the trans. you end up with six gears? You just have to get custom axles, shift linkage, etc.?
sorry i didn't mean for that to be offensive i just didn't want you to have the wrong info but from now on i just won't say anything...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">
thanks thats what I needed
I'm thinking about swapping the r motor in to an EK</TD></TR></TABLE>
but good luck with that
Holy, i can't believe u were actually being serious. I thought u were being sarcastic at first haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelemi821 »</TD></TR><TR><TD CLASS="quote">sorry i didn't mean for that to be offensive i just didn't want you to have the wrong info but from now on i just won't say anything...
It's all good there is just people on HT that do that **** all day long, don't be like them. Just try and add something to the conversation other than the obvious.
</TD></TR></TABLE>It's all good there is just people on HT that do that **** all day long, don't be like them. Just try and add something to the conversation other than the obvious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20whitevic »</TD></TR><TR><TD CLASS="quote">I'm running a K20A in my 2001 Civic, which I previously had a K20A2 in (Same setup as sig, but with TODA Spec A's w/o the TODA Header, Comptech instead). I don't have actual dyno numbers, but the engine itself does feel a little stronger, or maybe that's the TODA header..hehe..
I was able to get an entire DC5-R front clip for 4 thousand. It had everything except for the suspension.</TD></TR></TABLE>
have any pics?
have any pics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razen uta »</TD></TR><TR><TD CLASS="quote">the k20 type r made 267 to the wheels with k pro, header and intake thats it........
i still want to see where u got those numbers from. it just seems a little far fetched.
</TD></TR></TABLE>i still want to see where u got those numbers from. it just seems a little far fetched.
