Rattle in first gear
Old Mar 26, 2004 | 07:33 AM
3 plus 1's Avatar
Default Rattle in first gear
There's a metalic rattle/squeek coming from my engine bay whenever I'm coming out of 1st gear. It doesnt seem to do it when the car warms up. It sounds like something is loose and squeeking around. If I come out of 1st gear real slow I can make it make the noise real easy. Sounds something like a squeeky belt, but it only does it coming out of 1st. Once I'm in gear its fine. Not sure where to start looking.
Old Mar 26, 2004 | 07:37 AM
b18c_power's Avatar
Default Re: Rattle in first gear (3 plus 1)
Have you changed your tranny fluid recently? If not id try that first and if the noise doesn't go away it could be the shift fork or the throw out bearing. You only hear the sound in 1st gear?
Old Mar 26, 2004 | 09:07 AM
3 plus 1's Avatar
Havent changed the tranny fluid. I'll change it now. The sound only seems to happen in first gear, although I've heard a noise in second, but its not the same one. Probably same location though. I dont think it would be the shift fork. It goes into gear just fine and doesnt have any grinding problems. If anything it would be clutch related.
crazyhouse2011
33
Oct 14, 2014 04:40 PM
Kyle244R948
Nov 1, 2007 04:51 AM
kontakterr61
Sep 6, 2007 10:02 PM
gsr984dr
Feb 4, 2005 08:19 AM
Mires
Sep 20, 2002 01:17 PM
