new fuel upgrade
Old Mar 26, 2004 | 07:29 AM
LS stretch's Avatar
Default new fuel upgrade
alright i bought a walbro fuel pump, and obx fpr and rc 330cc injectors. two questions tho... 1- im gonna have to drop the tank to do the fuel pump wont i and 2- being that im OBD2 im gonna throw a good amount of codes wont i?
Old Mar 26, 2004 | 07:33 AM
tilt's Avatar
Default Re: new fuel upgrade (LS stretch)
http://www.c-speedracing.com/h...p.php
Old Mar 26, 2004 | 07:41 AM
LS stretch's Avatar
Default Re: new fuel upgrade (tilt)
what car is that being done on and also with the wiring. what color is positive and what color is negative. ( i mean the honda wiring. not the red/black that came on the new FP.)
Old Mar 26, 2004 | 08:01 AM
SuzukaBlueAP2's Avatar
just wondering, what are you using all this for ?
1. There is NO wiring on a Fuel Pressure regulator. So i don't know what you're talking bout there.
2. You should not throw any codes from those, however, by just dumping more fuel into your car, it can trigger codes for "system too rich". I've got a 255 lph fuel pump in my G3, and it didn't throw and CEL.
3. Don't know what year your car is, but, on a G3 for sure you don't have to drop the tank to install the FP. It installs underneath the rear seat.
4. back to the wiring, I don't know what kind of injectors you got, but, some after market injectors it doesn't matter which wire you hook up to which on the clips. I've wired the clips up on my RC 440s both way, and there is no difference.
Old Mar 28, 2004 | 02:57 PM
LS stretch's Avatar
Default Re: new fuel upgrade (ScreaminTeg)
the only thing i meant about wiring was which color is what on the fuel pump. meaning the new fuel pump i got came with a red positive and a black negitive. being that i havent takin out the stock fuel pump yet and looked at it i was wondering what the colors of the positive and negitive on the stock wiring of the pump were . not the fpr
Old Mar 31, 2004 | 07:56 AM
LS stretch's Avatar
Old Mar 31, 2004 | 09:07 AM
TypeRPaul's Avatar
i believe it is the same as the itr, but im trying to find out the same info to put in my fuel cut off swiches(i would do since ur changing it out anyways). but i believe the positive is the green and yellow wire, not sure of the negative.
Old Mar 31, 2004 | 11:11 AM
LS stretch's Avatar
Default Re: new fuel upgrade (TypeRPaul)
what exactly is involved in the fuel cut off
Old Mar 31, 2004 | 11:33 AM
PlastikOwl
Guest
Posts: n/a
just put a switch somewhere along one of the fuel pump wires... and hide it well, be creative. if it's off....fuel pump gets no power.
flanker
15
Jan 2, 2017 12:14 PM
Charlie Moua
Jul 13, 2012 07:55 PM
KooK
Nov 28, 2007 01:21 PM
big juan
Oct 29, 2005 06:59 AM
bravoecho11
Apr 26, 2005 06:44 AM
