91 Civic Si tuneup
Besides plugs, wires, fuel filter and a bottle of injector cleaner, is there anything else that I should fix/replace on a Si with 115K miles on it?
Thanks.
Thanks.
did you do the timing belt/water pump already? if not do so otherwise cap and rotor, pcv valve and oil...when was the last time you changed your tranny fluid as well?
