Please Check my oil feed line (pics)
Old Mar 25, 2004 | 09:22 PM
FredoSP's Avatar
Default Please Check my oil feed line (pics)
Edit:
New Pics!
Hey guys,
I'm concerned with the slope of the feed line, specifically where it curves by the A/C condensor to the turbo - I think it might be "too sharp".
Ideas/Suggestions .. Thanks
Modified by FredoSP at 10:57 AM 3/27/2004
Old Mar 25, 2004 | 09:25 PM
Hoosier Daddy's Avatar
Default Re: Please Check my oil feed line (FredoSP)
Looks bueno to me.
Old Mar 25, 2004 | 09:26 PM
vtec69's Avatar
thats a clean *** motor yO
-Brian
ahobbs's Avatar
HELLO,GOOD MORNIN'
I don't think it's a problem. correct me if I'm wrong But I believe I'm sure. It's pressure so it's cool
Old Mar 25, 2004 | 09:29 PM
BlackKnight7's Avatar
Default Re: Please Check my oil feed line (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it's a problem. correct me if I'm wrong But I believe I'm sure. It's pressure so it's cool</TD></TR></TABLE>
Yes, the feed line does have pressure, if it is hooked up to the oil "pressure" sender, which I believe is what he used for his oil feed source. Personally I routed mine under the engine, but that should work fine.
Jake D.
Old Mar 25, 2004 | 09:31 PM
FredoSP's Avatar
Default Re: Please Check my oil feed line (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">thats a clean *** motor yO
-Brian</TD></TR></TABLE>
And you see it in person just about every day!
Old Mar 25, 2004 | 09:33 PM
FredoSP's Avatar
Default Re: Please Check my oil feed line (BlackKnight7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackKnight7 &raquo;</TD></TR><TR><TD CLASS="quote">
Jake D.</TD></TR></TABLE>
Yes its routed from there, but now I'm wondering if its smart to have the line on the valve cover ... hmmmm
Old Mar 25, 2004 | 09:40 PM
SS braided line is some nasty stuff if left untamed it can work like a saw. This is especially bad for powder coated aluminum valve covers. I have mine zip tied in a couple places so it won't saw threw stuff.
Jake D.
Old Mar 25, 2004 | 09:56 PM
Blackack26's Avatar
hummm, it will work fine because the line is pressurized, but it's kinda fugly having it over the motor like that, try running it around the other side.
Old Mar 25, 2004 | 10:00 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
If you hit a bump or soemthing the valve cover and hood may sandwhich it and kink it. I would (and did) route it around the valve cover
Old Mar 25, 2004 | 10:06 PM
nevin's Avatar
or try running it around by the tbelt, but it looks as if it might not be long enough.
Old Mar 25, 2004 | 10:07 PM
Flamenco-T's Avatar
Default Re: Please Check my oil feed line (SIXTYdashONE)
Fred,
I told you this already, I think. Route it from the tranny side...it's easier and you'll have a better angle to mount them.
stan
Old Mar 25, 2004 | 10:28 PM
Flamenco-T's Avatar
Default Re: Please Check my oil feed line (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">
Fred Lisen to Stan </TD></TR></TABLE>
he's to busy checking out other guys hahah LOL J/K man
Old Mar 25, 2004 | 10:41 PM
ThePunk's Avatar
The braided lines do very BAD things to whatever they come in contact with.
We routed rachels around over the trans, and put a piece of slit rubber hose over it to prevent rubbing damage.
like this:
Old Mar 26, 2004 | 01:24 AM
lilxvtecxpwr's Avatar
Default Re: Please Check my oil feed line (ThePunk)
damn. looks like you bought every little nic nac brand new or something. kleen!
OT: how come ur block is so clean compared the pics of when ur block just got finished being assembled? is it painted?
EDIT: yea, you should route the oil line on the tranny side. if you leave it as is, it'll start scuffing up your valve cover and watever else its rubbing up against.
Old Mar 26, 2004 | 05:16 AM
kranked91dx's Avatar
as long as the oil feen line is not kinked your ready to go dude !
this one look pretty damn good to me, no prob's here
KRanked
Old Mar 26, 2004 | 05:40 AM
Boostfed's Avatar
New User
Default Re: Please Check my oil feed line (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">Fred,
stan</TD></TR></TABLE>
Old Mar 26, 2004 | 07:29 AM
vtec69's Avatar
Default Re: Please Check my oil feed line (lilxvtecxpwr)
Sure is painted
He painted everything possible on the motor and beleive me it looks damn good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilxvtecxpwr &raquo;</TD></TR><TR><TD CLASS="quote">damn. looks like you bought every little nic nac brand new or something. kleen!
Old Mar 26, 2004 | 07:51 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">Sure is painted
even the damm coolant over flow bracket and bolt!!!
Old Mar 26, 2004 | 07:57 AM
m R g S r's Avatar
I had mine runnin on the tranny side, no sharp bends, so it never gave me any problems. Also, it wasn't really coming in contact with anything, so nothing got chewed up.
Old Mar 26, 2004 | 09:09 AM
*Boostwerks*'s Avatar
mmm...shiney. Bling Bling is definetly the way to go..haha.
Old Mar 26, 2004 | 09:17 AM
Silverbeast's Avatar
Stan is correct, tranny side is nice. Could even use a 45 going into center section for a little easier connection.
Old Mar 27, 2004 | 07:00 AM
FredoSP's Avatar
Default Re: (Silverbeast)
I fixed the feed line, look at new pics above!
Old Mar 27, 2004 | 07:29 AM
Boostfed's Avatar
New User
Default Re: (FredoSP)
Bravo bravo(hand clap hand clap) Much better.
Old Mar 27, 2004 | 07:33 AM
I like the new routing much better
