mixing a Accel ign box w/MSD coil help???
ok, so this weekend i hooked up the Accel 300+.. and it was working fine till today.. when i went to meet my girl for lunch and i come back out, going to leave, and the car won't start???.. ok so i'm like WTF?.. no fire.. so i grap some wire and aligator clips for the store down the street, and bypass the ign box, and just use the MSD coil on the stock ignitor.. and it works
so i get home, and test the accel, its fine.. its firing a positive tigger.. but when i hook it up to the coil it won't fire??.. but the coil fires fine on the ground tigger from the stock ignitor?.. i call MSD they say no issues should work fine with the accel, in fact it works off a positive tigger not a ground??
so any ideas?, when iget off work, i'm gonna swap out the accel box with another one.. and see but i doubt it'll work, the accel is firing.. i have a test light to it?..
anyone running a Accel 300+ with a MSD Blaster SS coil?..
also , the Accel should just be hooked up with the white wire going on the tigger on the ignitor, right?.. well other then the 12+ and ground wires?
thanks in advance
thanks in advance
fugett
Mar 18, 2011 07:04 PM
