More power???
Old Mar 25, 2004 | 07:09 PM
1badcrx's Avatar
Default More power???
Ok my name is Josh and I am fairly new to the board, i drive a 1990 CRX, 1994 LS motor, intake, header, no-cat exhaust. I was just lookin to get some input from fellow crx owners on what would be the best, most inexpensive way to up the horse power.
Old Mar 25, 2004 | 07:17 PM
Redline130's Avatar
Default Re: More power??? (1badcrx)
First off, welcome to H-T. Probably the best bang for the buck would be nitrous. There may not be a more affordable way to get the kind of gains you would get with a good nitrous kit. Just be careful with it. If that's not too your liking, maybe look into some cams and cam gears, and try and get your car tuned on a dyno.
Old Mar 25, 2004 | 07:57 PM
jedubz's Avatar
NOS = cheapest power. next cheapest would be a a vtec head (converting it to an LS/VTEC), then next a home made turbo kit. (see http://www.homemadeturbo.com ) .... then next would most likely be built NA.
Old Mar 26, 2004 | 12:19 PM
93civic_sedan's Avatar
Ok this is 1badcrx im 93civic-sedan's buddy...what should I do if I really want to stay from "NAWZ"? thanks
Old Mar 26, 2004 | 03:22 PM
ceLtic's Avatar
N/A wh0re!
Default Re: More power??? (93civic_sedan)
get some higher lift cams with some head work. car will definitley respond a lot better.
Old Mar 26, 2004 | 06:30 PM
1QWKCRX's Avatar
Default Re: More power??? (ceLtic)
If you are like me and want to stay spray free, I'd say go
with a B16A head and a good VTEC controller such as an
APEXi VAFC.
Old Mar 26, 2004 | 06:46 PM
Kasper.'s Avatar
Default Re: More power??? (1QWKCRX)
Id buy a new clutch if you havent and throw in a j1-ys1 tranny, thats the only thing that is really keeping that ls motor from performing like it should(the torque that is) the gearing on those ls trannys suck and needs to be alot more aggressive....while your in there throw in an act clutch(my preference)
Now really that isnt to expensive and you'll notice that more then putting on stupid bolt-ons.
Otherwise Id save up and go LS/vtec but if you do it right then it should NOT be an inexpensive mod, this will cost alot if done properly, which is the only way it should be done.
Old Mar 28, 2004 | 10:10 AM
1badcrx's Avatar
Default Re: More power??? (Kasper-EF8)
I've heard that the air flow on the B18a's is pretty bad; so do u think that maybe a new intake manifold, and throttle body would help much. Thanks
boostedefhatch
Apr 11, 2009 01:50 AM
TypeR1558
Jan 19, 2003 10:31 PM
Nix_TEG
Dec 21, 2002 02:44 PM
It's James
Dec 20, 2002 05:46 AM
BluFire
Dec 16, 2002 09:35 PM
