pic request- GSR w/ VALVE cover oFF
Old Mar 25, 2004 | 05:10 PM
genetsang's Avatar
Default pic request- GSR w/ VALVE cover oFF
i know this is a hard one..... but i would appreiciate a gsr with its Valve Cover OFF
since i cant take off my valve cover... due to a stripped cap nut...
i want to see what would happen if i dremel the cap nut off.
Old Mar 25, 2004 | 06:56 PM
XtR-X's Avatar
Default Re: pic request- GSR w/ VALVE cover oFF (genetsang)
Good luck.
Old Mar 25, 2004 | 07:08 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genetsang &raquo;</TD></TR><TR><TD CLASS="quote">
i want to see what would happen if i dremel the cap nut off.</TD></TR></TABLE>
don't do that
you will get metal everywhere
just take off the rest of the nuts, and the stripped one, take the nut off all the way, the post will come of the head, and you will be able to take off the valve cover, at that point, you will be able to get a wrench on the post and take off the nut, and replace with a new post, and nut
Old Mar 26, 2004 | 04:39 AM
JimBlake's Avatar
Default Re: pic request- GSR w/ VALVE cover oFF (Dan GSR)
Maybe it's easier to see this way...
So you've got one of those studs #18 spinning along with it's top nut. If you can, take off the valve cover along with that stud/nut. Then cut it apart where the metal shavings won't get into the engine.
I know you've been spinning that thing for a while, so maybe it really won't come off like that. If you really can't get it off, grab the nut with a vise-grips & break it off. Whatever way you get it, you're still gonna have to buy a new stud (#18).
Old Mar 26, 2004 | 07:40 AM
genetsang's Avatar
Default Re: pic request- GSR w/ VALVE cover oFF (JimBlake)
thanks!
my problem is, i need to remove the cover to replace the valve cover gasket...
when i try to loosen cap nut on the BOTTOM LEFT corner of the valve cover (as seen in the pic) i assume that the cap and stud is spinning together at the same time.
no matter how long i try to loosen it. the cap nut wont seperate from the stud.. and it wont come loose.. so i tried the opposite. and it wont tighten either...
I was able to remove all the cap nuts on the valve cover.. the 3 outer nuts. and the 4 under teh park plug cover.
but i still cant manage to remove the last nut that is on the edge.
i was told in the other thread. the only thing i could do is. dremel the cap nut off....
Modified by genetsang at 11:54 AM 3/26/2004
Old Mar 26, 2004 | 07:54 AM
manekDC2.'s Avatar
i am having the same problem^^^^^
Old Mar 26, 2004 | 07:57 AM
genetsang's Avatar
Default Re: pic request- GSR w/ VALVE cover oFF (manikgsr)
niceeeeeeeeeeeeeeee!!!!! hahhaha
when i find out what how i fix my problem, ill let you know...
and if you find out first.. help a brother out
try this threadhttps://honda-tech.com/zerothread?id=808923
i posted it up my frustration there too.. but unless theres another way... i would greatly apprieciate it
Old Mar 26, 2004 | 08:26 AM
JimBlake's Avatar
Maybe it's already broken... Did you actually try taking off the valve cover the way it is? They usually stick from the gasket getting hard, so rap it with a soft mallet or something.
Old Mar 26, 2004 | 08:45 AM
vntperformance's Avatar
Or try this, tighten the living f*ck outta that nut on the top so it'll break off and then you can take the valve cover off and use the other end to loosen the broken piece off.
vnt
Old Mar 26, 2004 | 08:51 AM
VTECorona's Avatar
Default Re: pic request- GSR w/ VALVE cover oFF (vntperformance)
Listen to Dan GSR and do not dremel it. That could affect the overall life of your motor since metal shavings will be all over your valve train.
Old Mar 26, 2004 | 08:56 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vntperformance &raquo;</TD></TR><TR><TD CLASS="quote">Or try this, tighten the living f*ck outta that nut on the top so it'll break off and then you can take the valve cover off and use the other end to loosen the broken piece off.
vnt </TD></TR></TABLE>
i dont think he can, he said that he went one way to loosen it and it all just spun together, then went to tighten it and it spun together too... umm, i say just get a rag and work it in all the corners so metal doesnt get anywhere on ur head.. dremel the bitch off, go buy part #18, install it.. and it should be good..
i really dont see any other way to get that nut off if it spins with the bolt its on
Old Mar 26, 2004 | 09:17 AM
genetsang's Avatar
Default Re: pic request- GSR w/ VALVE cover oFF (..::91TEG-G2::..)
yeah im going to try everything that is possible..
i was acutally standing on the top on the struts trying to lift the valve cover off.
but still no good..
i guess i gotta take it to acura and have them rape me in the *** for their labor
DeDonDeRosa
K Series
Aug 31, 2015 04:26 AM
SteezyEG
12
Oct 28, 2012 02:23 PM
kornerk12
Oct 12, 2008 10:31 AM
Moto DC2
Dec 26, 2007 11:59 PM
KLN
Jan 26, 2002 04:21 PM
