broken hasport mount pics...
Old Mar 25, 2004 | 04:35 PM
90civichbsi's Avatar
Default broken hasport mount pics...
i posted this https://honda-tech.com/zerothread?id=808849 a couple days ago and said i would post some pics. im sure the new mounts are stronger than these, but these mounts have been installed on a couple cars. and been put through a few years of use.
but dont worry hasport is taking care of me, i sent back my mount and as soon as they get it they are sending me a new prebillit mount to replace it. to hasport for customer service.
Modified by 90civichbsi at 1:50 AM 3/26/2004
Modified by 90civichbsi at 5:06 AM 3/26/2004
Old Mar 25, 2004 | 04:38 PM
DC 2's Avatar
Default Re: broken hasport mount pics... (90civichbsi)
holy ****, you got your use out of those! Gotta love Hasport Customer service
Old Mar 25, 2004 | 04:41 PM
2point2's Avatar
How much power are you making?
Old Mar 25, 2004 | 04:52 PM
Default Re: broken hasport mount pics... (2point2)
a whoppin 150hp and 110tq to the wheels
b16 w/ I/H/E and an act HDSS clutch
Old Mar 25, 2004 | 06:03 PM
b16_madman's Avatar
Yeh if it wasn't for their customer service, i'd try others.
Old Mar 25, 2004 | 06:32 PM
hyperlite1080's Avatar
I have those mounts, i hope that never happens to me
Old Mar 25, 2004 | 06:42 PM
T S R Performance's Avatar
Default Re: (hyperlite1080)
usually after alot of wear that will happen to pretty much all alumnium. stress lines and all of that. not bad for a few years of wear and tear. good job on the bust
Old Mar 25, 2004 | 08:03 PM
Default Re: (CivicHatchSOHC)
yeah at least it was the easiest mount to get too, All i had to do was support the motor, remove the starter, and undo the bolts. (I have a relocated battery so that wasnt in the way) didnt take much more than 20 minutes with hand tools.
also you can see how the bushing looks chewed up, and the rear lip was worn off, i dont know how long the mount has been broken, but about a week ago i didnt see that my motor was leaning.
Old Mar 25, 2004 | 08:19 PM
rsbad454's Avatar
Default Re: (90civichbsi)
damn.......i never saw one of those break before..... that sucks, but its good your getting a new one....
Old Mar 25, 2004 | 10:32 PM
Ben Ogle's Avatar
Default Re: (rsbad454)
Id imagine they will send you a billet one and the billet ones are much thicker around that area.
ben
Old Mar 25, 2004 | 10:50 PM
Default Re: (Ben Ogle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ben Ogle &raquo;</TD></TR><TR><TD CLASS="quote">Id imagine they will send you a billet one and the billet ones are much thicker around that area.
ben</TD></TR></TABLE>
na, they told me over the phone they are sending me a pre billet mount, im guessing they still produce them or have some left over for guys like me
Old Mar 25, 2004 | 11:03 PM
CyniKal.Mindset's Avatar
are all mounts aluminum or is there a company that makes solid steel ones?
Old Mar 25, 2004 | 11:18 PM
turbo2's Avatar
HCP, place racing(amybe), immitation made in China mounts are steel.
Old Mar 25, 2004 | 11:27 PM
ijjz's Avatar
Its nice you are getting it replaced. I've always read threads about HASport having great customer service. Props to them.
Old Mar 26, 2004 | 12:17 AM
SleeprCrx's Avatar
hey, the same thing happened to me last summer... same setup too... b16a i/h/e rps stage 3 clutch...Weird huh... and they call the b16 torqueless... lol... anyhow, hasport was good about replacing it...
Old Mar 26, 2004 | 03:05 AM
japspecjohn's Avatar
Default Re: broken hasport mount pics... (SleeprCrx)
They are expensive...I guess you pay for the service though
Old Mar 26, 2004 | 03:13 AM
RobbieG35's Avatar
12 Years Strong
Default Re: broken hasport mount pics... (japspecjohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">They are expensive...I guess you pay for the service though </TD></TR></TABLE>
I agree to Hasport for taking care of their customers
Old Mar 26, 2004 | 04:00 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperlite1080 &raquo;</TD></TR><TR><TD CLASS="quote">I have those mounts, i hope that never happens to me</TD></TR></TABLE>
You may or may not have those mounts. The mounts pictured here are their original, welded style mounts. Back in ~2001, breakage of the ring around the bushings (as pictured) was quite common. So Hasport decided to make a similar style of mount that is made of heavier material. I know this because I have one of their first sets of these improved original (welded) style mounts. So if you purchased your kit between about spring 2001 and the time that they went with the billet kit, you should not have any problems. The improved 'classic' style mounts are distinguished from the first ones by the use of MUCH heavier material in the rings around the bushings on the driver's side and passenger side transmission mount. The rear mount is subject to ALOT less stress and didn't get the heavier material.
Old Mar 26, 2004 | 12:14 PM
Destroyer24Seven's Avatar
Default Re: (StorminMatt)
Dam!
Old Mar 26, 2004 | 12:28 PM
rice_classic's Avatar
Default Re: (Destroyer24Seven)
My hasport mounts are billet aluminum so I guess I won't be having this problem.!
Hasport will probably replace them with the newer better units.
Old Mar 26, 2004 | 12:32 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">...Hasport will probably replace them with the newer better units.</TD></TR></TABLE>
NOPE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">
na, they told me over the phone they are sending me a pre billet mount, im guessing they still produce them or have some left over for guys like me</TD></TR></TABLE>
Sounds shitty at least you would get another free one if it breaks again. but then you have to go through taking it out again and re-installing it.
to their customer service though
Old Mar 26, 2004 | 03:46 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
same here, there like a inch think, unlike the pictured ones...
Old Mar 26, 2004 | 03:48 PM
SleeprCrx's Avatar
Default Re: (Jurassic Four)
When mine broke, they sent me a billet one... I thought that was great customer service...
Old Mar 26, 2004 | 04:18 PM
Default Re: (SleeprCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeprCrx &raquo;</TD></TR><TR><TD CLASS="quote">When mine broke, they sent me a billet one... I thought that was great customer service... </TD></TR></TABLE>
interesting... he said i would get a prebillet on the phone. i guess ill see what they do.. but id prefer to have all of the same type of mounts in my engine bay though.
Old Mar 26, 2004 | 05:27 PM
95DXCIVIC's Avatar
big for hasport takin care of their customers
