B16a trouble
Old Mar 25, 2004 | 04:32 PM
piles69247's Avatar
Default B16a trouble
Ok I got a b16a still obd0. When I drive it and it is below 3500 rpm it sounds and feels like it will load up with fuel and just bog down like it is flooded. I changed sparkplugs,wires,distri,cap and roater, and turned all the fuel settings on the vafc to stock. It is still doing it. It had a ls/vtec in it at one time. I took each plug wire off of the plugs one by one when the car was running and it did what it was suppose to do when you loose spark on a plug. I am still useing the same chiped ecu. Could that be the problem. Another thing is when I put a load on the motor it works great it only happens in normal day to day driveing. Any help would be great.
Christian
Old Mar 25, 2004 | 04:36 PM
turbocivic96's Avatar
Default Re: B16a trouble (ef9b16a)
Any CEL? It sounds to me like its a timing issue. DO you have cam gears on it and what size injectors are you running?
Old Mar 25, 2004 | 04:39 PM
piles69247's Avatar
Default Re: B16a trouble (turbocivic96)
Stock injectors. Timeing was good lastnight when we were looking at it.
Old Mar 26, 2004 | 05:52 AM
Harassing Herbs's Avatar
check fuel pressure.
Old Mar 26, 2004 | 06:37 AM
RTE117's Avatar
Do you have an AFPR? What fuel pressure is it at? When my fuel pressure was too high my car had lag.
Ryhaz
16
Mar 16, 2014 07:13 AM
jacksongo
Apr 15, 2011 08:44 PM
yeahkkyle
Sep 23, 2009 02:24 AM
Sleepingcrx
Jun 18, 2006 07:55 PM
