Moonroof problem
Old Mar 25, 2004 | 04:03 PM
JFG Kevin's Avatar
Default Moonroof problem
It WON'T OPEN...well..it trys...it gets half way up and it get stuck...looks like the window moves back b4 it goes it...that's what i'm thinking is wrong...help.. can you also post a pic of ur moonroof close and see how it flush out with the body...
Old Mar 25, 2004 | 04:11 PM
King_j's Avatar
Default Re: Moonroof problem (aznstyler119)
if the motor is working it sounds more like a track problem. try greasing it then shut it.
Old Mar 25, 2004 | 06:09 PM
JFG Kevin's Avatar
Default Re: Moonroof problem (King_j)
it's a 2000...hehe...i dont think it's greasing that is needed...but yah...thx fo the advice....another other have had the same problem?
Old Mar 25, 2004 | 06:11 PM
drastikchangez's Avatar
my 2000 civic use to do that it had dirt on the track. clean it then use some grease
Old Mar 25, 2004 | 08:30 PM
PushinRedline's Avatar
i have a complete sunroof assembly for sale in case you need one.
Old Mar 25, 2004 | 08:44 PM
JFG Kevin's Avatar
Default Re: Moonroof problem (drastikchangez)
did your moonroof..use to go back first...b4 it pop open...mines does that rite now...and when it moves back...the rubber peice...gets stuck with the roof
Old Mar 25, 2004 | 09:02 PM
JFG Kevin's Avatar
Bump.....moonroof still stuck!!!
Old Mar 25, 2004 | 09:10 PM
Smeeg Heed's Avatar
did you just get this car? If so then the integra moon roof looks like it should be going back more since it still overlaps about 3 or 4 inches even when completely open.
If not then how far did it go back before this as compared to now?
Old Mar 25, 2004 | 09:26 PM
JFG Kevin's Avatar
Default Re: Moonroof problem (NS98GSR)
the moonroof is stuck CLOSED...when i try to open it...i have to push it up by hand first then it'll retrack back...what it does is when i open it...it moves the moonroof back b4 it even goes up first...to slid back.....i clean and grease the tracks aready..didnt work...what i had to do was adjust the window...but after adjust it...a couple more uses...it's bak to being stuck at the same spot...and when i adjust the level of the window...it's not flush with the body
Old Mar 25, 2004 | 09:49 PM
JFG Kevin's Avatar
just read on team integra...the seal needs lub...but what kinda lub should i use?
Old Mar 26, 2004 | 01:36 AM
i bought some grease from honda check to see if its off track
Old Mar 26, 2004 | 09:30 AM
JFG Kevin's Avatar
i got it to work..lub it up with silicone originally use for my camber kit for squeak...works...great...and i so adjusted the window....the front part of the window (toward the hood) move it down...and back part (toward the trunk) move it up...the window isn't all that flush out...but it's not noticable if i dont tell you abou it
Old Mar 26, 2004 | 10:13 AM
WRTEG's Avatar
i had the same problem with my 94 ls about 2 days ago, clean it and grease it , and it should be fine, mine used to go back about a inch and stop, it would open and close fine just would only move about a inch, i think you have the exact same prob.
jeffrox626
Mar 4, 2011 05:55 AM
Projectjdm4
16
Apr 27, 2008 02:53 PM
taffetawhitegsr
Jul 23, 2004 10:37 AM
eg_coupe94
Jul 6, 2004 10:41 PM
dyases
Jan 9, 2003 01:43 PM
