will this blow my motor up?
Old Mar 25, 2004 | 03:57 PM
kaptr1d's Avatar
Default will this blow my motor up?
ive been working on a motor build up for a while and until recently i hadnt considered going turbo because of my lack of knowledge on turbo maintainence etc.
a friend of mine suggested the turbo route after i divulged the price tag of the an-r header i am saving for.
question is this: can i run a skunk2 stage2 cam setup with appropriate valvetrain and 6-9 psi boost on stock bottom end without blowing up?
my current goal was 200hp all motor, so hondata was already on the list of things to do. obviously with a turbo i could make a lot more power. at what reliability price though?
thanks for advice, im a turbo newbie. :]
Old Mar 25, 2004 | 04:07 PM
Hoosier Daddy's Avatar
Default Re: will this blow my motor up? (kaptr1d)
Grant, just buy my turbo and manifold for less than what you'd buy that header for.
Old Mar 25, 2004 | 04:58 PM
99B16Si's Avatar
sell the skunk2's and get some gsr cams. theres 500bucks, then buy a turbo kit for about 2000-2500 and youll be a lot happier than with your all motor BS
Old Mar 25, 2004 | 05:00 PM
kaptr1d's Avatar
Default Re: will this blow my motor up? (99B16Si)
so ill have problems with the stage2 cams?
i really wanna keep them :*(
Old Mar 25, 2004 | 05:02 PM
99B16Si's Avatar
too much overlap for boost IMO
Old Mar 25, 2004 | 05:18 PM
kaptr1d's Avatar
Default Re: (99B16Si)
i figured that would be the answer. i need to make up my mind about which direction im gonna go before it gets warm out.
wouldnt want to change my cams, break in the motor again, and then change my mind.
nick, u suck.
Old Mar 25, 2004 | 05:40 PM
warwagon's Avatar
Default Re: (kaptr1d)
i went all motor, and if i would have put that damn 5 grand into my motor for turbo i would prolly still have that car, so now i am hooking up a d series kit for more power than my all motor 2.0 ls vtec
notasleeper
Jan 9, 2006 07:41 PM
SD1222
14
Jan 2, 2005 09:36 PM
Boosted GSR
Apr 7, 2003 10:57 PM
Thrillhouse
Jul 20, 2002 08:41 AM
InfamousRS
Jan 16, 2002 06:17 PM
