98-01 GSR: Stock Shifter
Old Mar 25, 2004 | 03:44 PM
joshalee's Avatar
Default 98-01 GSR: Stock Shifter
Is it normal for shifter to slip out of gear and back into w/o pressing down on the clutch?
I find when I am in 3rd, it can slip out easily and back in easily.
Old Mar 25, 2004 | 03:45 PM
Ti3d in's Avatar
Default Re: 98-01 GSR: Stock Shifter (joshalee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshalee &raquo;</TD></TR><TR><TD CLASS="quote">Is it normal for shifter to slip out of gear and back into w/o pressing down on the clutch?
I find when I am in 3rd, it can slip out easily and back in easily.</TD></TR></TABLE>
That's never happened to me. Does it grind when it does that?
Old Mar 25, 2004 | 03:46 PM
yung98gsr's Avatar
You must be playing with it a lot. I can see slipping out but back in without grinding is amazing.
Old Mar 25, 2004 | 03:52 PM
joshalee's Avatar
Default Re: (yung98gsr)
No grinding...maybe once or twice.....but it can easily slip out if i move into N and then back into the gear.
Happens at certain speeds and RPM's. I try not to do it as much, but it's becoming a habit.
Would it ruin anything?
Old Mar 25, 2004 | 04:04 PM
weakGOODJunKieS.com's Avatar
Default Re: (joshalee)
it happens to me too. it slips back into N from 5th really smooth... dont know if its harmful because i dont do it on purpose. i doubt it can be good.
Old Mar 25, 2004 | 04:05 PM
JFG Kevin's Avatar
i think for sure...that with 3rd and 4th gear...it will slip out...with some pressure to it...but back in without rev match..and no grind...i dont know about that
Old Mar 25, 2004 | 05:10 PM
GSRontheBottle's Avatar
i had mine slip out of 5th the other day but it didnt make it into another gear and hasnt happened since..
Spinks
Honda Civic (2006 - 2015)
Nov 23, 2010 06:01 PM
mugen727
Sep 30, 2009 09:16 AM
LShatchie
18
Feb 24, 2006 08:00 PM
alfaaay
Apr 24, 2003 12:36 AM
