b16a into 89 civic - anyone not used a mount kit?
Old Mar 25, 2004 | 01:48 PM
tinkerbell's Avatar
Default b16a into 89 civic - anyone not used a mount kit?
swapping a B16A from a '90 JDM integra Xsi into a '89 civic...
do i have to use a mount kit or can i use the stock mounts from the Integra?
has anyone tried this? is it too much hassel?
i have already installed a B16A in a 83 Prelude, but had to weld some chassis mounts in...
are the gearbox mount and front engine mount going to line up OK? i have eyeballed it and think so...
any suggestions appreciated
Old Mar 25, 2004 | 01:53 PM
TRAY's Avatar
Default Re: b16a into 89 civic - anyone not used a mount kit? (tinkerbell)
https://honda-tech.com/zerothread?id=637661
Old Mar 25, 2004 | 01:56 PM
tinkerbell's Avatar
Default Re: b16a into 89 civic - anyone not used a mount kit? (TrayDay2K1)
no offence man, but i have read the FAQ and i could not find any links relating to the non-use of a mount kit in a 89 Civic when swaping a B16A in...
if you are certain that this answer is in there, could you please assist by pointing out which part of the FAQ relates to my question?
thanks!
edit - spelling
Old Mar 25, 2004 | 02:12 PM
wtsexton's Avatar
Seeing you are from down under. If the car has a D series engine in it then yes you'll need a mount kit. If the car has a b16a then it will be a direct swap.
Old Mar 25, 2004 | 02:15 PM
tinkerbell's Avatar
Default Re: (wtsexton)
so you are saying i HAVE to use a expensive mount kit?
there is no other choice?
i find that hard to believe!
Old Mar 25, 2004 | 02:17 PM
YumVTEC's Avatar
Default Re: (tinkerbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell &raquo;</TD></TR><TR><TD CLASS="quote">so you are saying i HAVE to use a expensive mount kit?
i find that hard to believe!</TD></TR></TABLE>
no, you don't. but you have to cut off the US passenger side upper transmission mount and relocate it further forward in the engine bay. The front transmission mount will not bolt up if you do it this way, and since you are using stock mounts with rubber inserts in them, you will have a lot of flex as your engine revs.
my friend bought a b16 crx that was done this way a long time ago before mount kits were widely available. it interferes with battery placement too, so be aware.
Old Mar 25, 2004 | 02:21 PM
tinkerbell's Avatar
Default Re: (YumGTR)
that is what i <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumGTR &raquo;</TD></TR><TR><TD CLASS="quote">
no, you don't. but you have to cut off the US passenger side upper transmission mount and relocate it further forward in the engine bay. The front transmission mount will not bolt up if you do it this way, </TD></TR></TABLE>
that is what i had to do when swapping a B16A into my 83 Prelude...
i also had to move the LHS mount too - will i have to do this in the Civic?
how do you mean the front mount wont bolt up? do i need to relocate this left or right or does it go too far forward?
thanks,
Old Mar 26, 2004 | 09:09 PM
tinkerbell's Avatar
anyone else know of this swap being done without a mount kit?
Old Mar 26, 2004 | 11:26 PM
Fobtions's Avatar
ive done it before, when mount kits werent available.
timing belt side mount - use a 90-91 integra or the jdm b16a one.
tranny side mount- drill out spot welds , when u have your preferance on engine position reweld accordingly.
at the same time relocate the rear mount using the 90-91 L bracket , and repositioned mounton the rear crossmember
Old Mar 27, 2004 | 05:31 AM
XEF-9X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell &raquo;</TD></TR><TR><TD CLASS="quote">anyone else know of this swap being done without a mount kit?</TD></TR></TABLE>
ya my buddies old crx was done before mount kits were made. you just use the stock b16 mounts. you have to cut , and weld the medal mount locations on the chassis of the car for this to work. alot of unnessecary work IMO. if you **** it up and dont line it up just right it wont work! just get the mount kit. you can get HCP for 275 or AZ fab for 285.
Old Mar 27, 2004 | 08:22 AM
NCchris's Avatar
see: http://hybrid2.honda-perf.org/tech/4gtech.html
old school stuff and the pics dont work anymore but good info anyway. Som of the links still work.
HTH
chris
Old Mar 27, 2004 | 09:00 AM
bluecrxsi's Avatar
if you use hasport mounts it will line up so easy you wont believe it! just my 2 cents. but thats the way to go if you can.i know from experience
Old Mar 27, 2004 | 09:06 AM
johnzm's Avatar
Default Re: (bluecrxsi)
u guys ae overlooking the fact that dude could save 300 bux if he can do it himself.
personally i kinda ishi had the stock mounts in there the hasports are a little stiff for my likes as a daily
Old Mar 27, 2004 | 09:22 AM
XEF-9X's Avatar
Default Re: (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">u guys ae overlooking the fact that dude could save 300 bux if he can do it himself.
personally i kinda ishi had the stock mounts in there the hasports are a little stiff for my likes as a daily</TD></TR></TABLE>
The work he would have to put into it is more than 300 dollars of labor.
HCP mounts dont vibrate nearly as much as hasports. not everyone HAS
TO USE HASPORTS.
Old Mar 27, 2004 | 05:55 PM
tinkerbell's Avatar
Default Re: (XEF-9X)
yeah - thats right, not everyone ahs to use a mount kit.
thanks to you guys who have confirmed my idea. it is easy to drill out and reweld mounts...
i have done it in my 83 prelude:
http://www.geocities.com/b16ap....html
teh cost of the mounts is fair, but i have to import into Australia and the costs of tax and shipping doubles the landed cost downunder...
hence my reluctance to do this, when a professional weldign job = about 150 US...
ONE more question - can i swap the integra gauge cluster into the Si CRX ?
cheers everyone
redneckman936
Jul 16, 2016 05:59 AM
T--Rex
46
Jul 27, 2004 11:46 AM
VWkila
Jun 5, 2004 05:06 PM
w-fuck-ay
11
Aug 3, 2003 09:15 PM
91sifreak
Feb 8, 2002 08:26 AM
