removing door panels
i have searched and ive found jack on multiple websites... i need to get my doorpanels off on my 95 EX coupe so i can get to the side molding clips.. i have no idea how to take the panels off.. can i get some help
needle nose pliers - remove the pin for the window crank
phillips scredriver- remove the handle cup and the screw in the handle housing
hands-juss pry the door panel off, its held on with clips
Take off the screw in the door handle thing, screw in the pocket in the door panel, plastic screw near the front of door panel towards the car. Then pull out those plastic pieces and unhook your power accessories (power windows, locks, etc.). Then slowly pry/pop off the door panel from the edges and work your way all the way around.
done it twice, i have a 96 ex coupe, the same car almost. unsrew the the screws in the hand cup and behind the door latch and around the speaker in the door. then at the back of the door(end closest to the rear) use your hand(s) to pry the panel of. dont be afraid to pull a little. dont break the clips. they should pop loud they go down the back bottom and front of the panel. disconnect the wires going to the lock and window buttons. for the door latch, work the panel around it, should come off. its a pain in the *** to get back on though. gotta tip the panel and put it on on the top first then slide it down. really difficult. good luck. let me know how it goes
raybord
Aug 11, 2004 04:59 PM
