Zip tie brake lines after coilover install
Old Oct 22, 2001 | 08:46 PM
RineRacing's Avatar
Default Zip tie brake lines after coilover install
Has anyone had problem with zip tying brake lines after installing a coilover?
I tied mine like this to keep them from hanging loose.
Old Oct 22, 2001 | 09:56 PM
MrBite's Avatar
Default Re: Zip tie brake lines after coilover install (Geratol)
Pshhh, you know you just wanted to show off your new coilovers. Damn they look nice
Old Oct 23, 2001 | 02:50 PM
owen_the_soyboy's Avatar
Default Re: Zip tie brake lines after coilover install (MrBite)
Old Oct 23, 2001 | 04:15 PM
RineRacing's Avatar
As a matter of fact I tried asking this same question without using a pic and got no help. So this time I tried to get a little attention and some advice.
Old Oct 23, 2001 | 04:21 PM
B18b Turbo's Avatar
New User
its ok to zip tie you brake lines. i did this onmy 88 crix and havent had a prob yet. just use high strenght zip ties not the wimpy skinny ones they"ll "snap".but you should be straight
Old Oct 23, 2001 | 05:22 PM
SpiceyRice's Avatar
Default Re: Zip tie brake lines after coilover install (LS CRIX)
I zip tied them to the middle of my spring. Seems to be fine,,
Old Oct 23, 2001 | 05:53 PM
MrBite's Avatar
Yeah just f'in with ya...it is a sweet looking setup though. I don't think you can go wrong with zip ties--just check them every so often
Old Oct 24, 2001 | 04:25 AM
eg6ajk's Avatar
yes get the heavy duty zip ties, tied them very close, through out the whole brake line (rubber part only).....indeed it does make a difference in feel, not as good as SS lines but then again it doesn't cost much...
defiantly approved
Poey2
Suspension & Brakes
Aug 30, 2007 09:36 PM
whteteg8901
Suspension & Brakes
Feb 27, 2005 07:51 AM
LSiTurbo
21
Sep 7, 2004 08:31 AM
Flux
May 27, 2003 07:48 PM
NunRacer
Mar 23, 2003 11:02 PM
