JDM Folding Mirrors and Radio Shack relay
Old Mar 25, 2004 | 01:09 PM
superthug's Avatar
Default JDM Folding Mirrors and Radio Shack relay
I got the mirrors but they came without the oem relay.
I've read that I can use the Radio Shack relay # 275-0249.
Has anyone used it and got the mirrors to work?
How would they be wired to an alarm?
Old Mar 26, 2004 | 06:21 AM
superthug's Avatar
Default Re: JDM Folding Mirrors and Radio Shack relay (superthug)
ttt
Old Mar 27, 2004 | 07:30 PM
superthug's Avatar
is there manually a way of connecting the mirrors just to see if they fold/unfold?
there's white wire and a black wire that are in a seperate wire loom than the others. Could they be it?
Old Mar 29, 2004 | 06:06 AM
jerseywagon's Avatar
http://www.geocities.com/dwnlow91/JDMmirror.html
try this
Old Mar 29, 2004 | 07:39 AM
superthug's Avatar
Default Re: JDM Folding Mirrors and Radio Shack relay (jerseywagon)
thanks, i also found this tutorial to use the radio shack relay
http://students.washington.edu...s.htm
I setup up the radio shack relay as demonstrated in the tutorial. It works and all but when you hold the fold button, the mirrors fold but when you let go they unfold. So that means to leave them folded, I gotta turn off the car to cut the power. Hmmm...
I might just wire them up the door lock actuators since they switch polarity and would work with arming and disarming the car.
Now that I think of it, my doors lock minutes after the car is moving so that would cause the mirrors to fold. Or I could just disable that. Decisions, decisions...
Old Mar 29, 2004 | 09:30 AM
rjr162's Avatar
or you could make a latching relay circuit to mimic the cutting the ground, and then use the "open button" not only to open the mirrors but to unlatch the relay
Old Mar 29, 2004 | 10:55 AM
superthug's Avatar
Default Re: JDM Folding Mirrors and Radio Shack relay (rjr162)
is this the one you're talking about
Latching Relay
http://www.the12volt.com/relays/page5.asp#lsp
PURPLERANGER
Jun 25, 2014 08:14 AM
95halx
Aug 29, 2012 07:53 PM
95gsrturbo
Aug 2, 2003 11:46 PM
K20 EG
Jan 27, 2003 06:37 AM
