valve cover bolt stuck... need some advise.
i noticed some oil leaking from the valve cover today.. so i decided to take a stab and change the valve cover gasket for the gsr...
THe nuts that i am talking about are not the ones under the spark plug cover, but they are the 4 nuts on the outer edge of the valve cover.
anyways.... i was only able to loosen 3 of the outer valve cover nuts... but the 4th one seem to be spinning together with the bolt...
i say this b/c when i was loosening it, i have noticed that i was turning it for a while. and the nut is still not coming off the bolt.
does anyone have any suggestions?
i tried to pull the nut off with the vise grip
but it still didnt budge.. it seems like the bolt and nut is spinning together
hmmm damit.. i guess thats the only thing left to do
if i dremel off the nut.. what would i have to do, inorder to replace the stud of the outer valve cover?
any one know?
over tightening it is definitely a bad idea.
any one know?
