Did a compression test today.
187 accross the board after cranking it many times. Seems a little lower than the last time i did one, but im just glad they are all the same. What numbers are you guys gitting?
Engine temp was 136 degrees, when it is fully warm it reaches 158. I did a test about a month ago and if i remember correctly i hit 210 across all for cylinders. But just recently a shop was tuning my car and the boost controller wasnt working properly and i hit 10lbs of boost and had a a/f ratio of about 15.6. Soon after that i found that my fuel regulator went bad. I would have thought that if i had fucked something up that the numbers would have been differenent than each other. Anyhow, i have 107,000 miles on the motor.
yeah that compression does seem kind of low. i have a 92 jap prelude motor and it made 220 all the way across. did you crank the motor 5-7 times?? try again maybe you'll get different resluts
http://www.prodigyworks.com
