Does Anybody here AutoX is there turbo charged honda?
Old Mar 25, 2004 | 09:56 AM
jdmjay04
Guest
Posts: n/a
Default Does Anybody here AutoX is there turbo charged honda?
I was thinking of turboing my ride and seeing if this is possible with little or no problems on a stock block and pushing the car for such a long period of time in a autoX event.
Modified by jdmjay04 at 7:06 PM 3/25/2004
Old Mar 25, 2004 | 09:57 AM
J337_UNIT's Avatar
Default Re: Does Anybody here AutoX is there turbo charged honda? (jdmjay04)
i would like to know also
Old Mar 25, 2004 | 10:04 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjay04 &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of turboing my ride and seeing if this is possible with little or no problems on a stock block.</TD></TR></TABLE>
i dont get ur msg....
please spend some more time, be more clear and specific
Old Mar 25, 2004 | 10:08 AM
underpressure02's Avatar
I would like to know also I am thinking about trying autocrossing this weekend in my hatch at honda day. But I do now know what the car will do once boost hits. I think you pretty much run around in second and third gear. In those gears when my turbo spools the tires break loose. I can just see myself going into a corner and hitting boost and taking out all the cones.
Old Mar 25, 2004 | 10:16 AM
Matt B's Avatar
Default Re: Does Anybody here AutoX is there turbo charged honda? (underpressure02)
the gas pedal is not an on/off switch
Old Mar 25, 2004 | 10:32 AM
Default Re: Does Anybody here AutoX is there turbo charged honda? (Matt B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt B &raquo;</TD></TR><TR><TD CLASS="quote">the gas pedal is not an on/off switch</TD></TR></TABLE>
your right it is just an on switch.
Old Mar 25, 2004 | 11:24 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know also I am thinking about trying autocrossing this weekend in my hatch at honda day. But I do now know what the car will do once boost hits. I think you pretty much run around in second and third gear. In those gears when my turbo spools the tires break loose. I can just see myself going into a corner and hitting boost and taking out all the cones. </TD></TR></TABLE>
i dont think it will be a big deal, my friend tells me he rarely gets out of second gear
Old Mar 25, 2004 | 11:27 AM
hybridsol's Avatar
Default Re: Does Anybody here AutoX is there turbo charged honda? (Deluzional)
Yep, sure do. Ckeck out the videos... on web page.
http://home.comcast.net/~tailwags
Old Mar 25, 2004 | 11:33 AM
warwagon's Avatar
i used to race rc cars and it took me a while to learn that
Old Mar 25, 2004 | 11:41 AM
b18b98's Avatar
Default Re: Does Anybody here AutoX is there turbo charged honda? (warwagon)
I'm gonna try it out on May 23rd. I'm gonna have my mbc set to low boost (6-7psi) and see what happens. This is the schedule for NASA northeast region...
http://www.nasanortheast.org/register.htm
quick question..should i use my 14' drag radials or use my 15' nittos?
Old Mar 25, 2004 | 04:40 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Does Anybody here AutoX is there turbo charged honda? (b18b98)
you shouldn't have much problems, at least I haven't.
I don't knw how much hp you are putting, but I have around 200whp mustang dyno, and I've autoX in it with the turbo stock block b16. I haven't had any problems. You aren't really running it that long, autoX courses only last for abotu 40-80 seconds, and you aren't hitting full boost if any boost during that whole period. Boost comes in burst while autoXing, you aren't pedal to the metal for the whole time. After all, there are quite a number of turns you need to negotiate through. MOst of the time, you are trying to concetrate on taking the corner correctly, and setting up for the next corner. Straightaways aren't very long, and don't last that long either. The fastest I hit in a AutoX was about 70mph or so, and that was for less than a second before I had to start mashing on the brake and get ready for the corner.
You honestly shouldn't have any problems autoXing yoru car in a turbo stock block.
If your tires are breaking loose, then use your head, and don't MASH it so hard when coming out of a corner, or wherever. Ease the throttle. Think about it, whne you drag, you don't just SLAM on the gas and spin your tires forever to get that fast time, you play with the clutch, you adjust your throttle for optimum acceleration AND grip. In AutoX, you do the same thing when you have a high powerd fwd. If you feel the tires breaking loose, don't get so hard on it out of the corner. Apply just enough gas to get teh car accelerating well and keep adding as much as you can without breaking the tires loose.
........LSD helps a lot If you don't have one in autoX and you're driving a high pwrd fwd, you going to see a lot of smoking inside tires while cornering.
fled
Jan 9, 2007 05:34 AM
Jeffescortlx
Sep 19, 2004 09:05 AM
turbotypeR@SPEC
Jan 21, 2004 05:31 PM
oMek
Oct 17, 2003 01:21 PM
