New Si springs and New Civic springs??
Old Mar 25, 2004 | 08:26 AM
WhatItDo's Avatar
Default New Si springs and New Civic springs??
Are the springs the same on these two cars? like if you got some lowering springs for an Si would they work on a new Civic LX? thanks
jaydub's Avatar
Default Re: New Si springs and New Civic springs?? (Moogen)
I'm sure the spring rates are different.
Old Mar 25, 2004 | 08:36 AM
WhatItDo's Avatar
Default Re: New Si springs and New Civic springs?? (jaydub)
so youre sayin that you CANT use the Si springs for the LX??
Old Mar 25, 2004 | 08:38 AM
jaydub's Avatar
well going that direction you probably could use Si springs. I apologize, I thought you meant using EM2 springs on a EP3 (which you could also do, however I am seeing the ill effects of that).
Old Mar 25, 2004 | 08:40 AM
WhatItDo's Avatar
thanks man... its not for me, my friend wanted to know so i was just gonna tell him... i guess i should tell him not to
Old Mar 25, 2004 | 09:48 AM
DC5 03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydub &raquo;</TD></TR><TR><TD CLASS="quote">well going that direction you probably could use Si springs. I apologize, I thought you meant using EM2 springs on a EP3 (which you could also do, however I am seeing the ill effects of that).
EM2 Tein S-tech's are even softer than stock EP3 spring rates I'm guessing?
Old Mar 25, 2004 | 09:53 AM
jaydub's Avatar
Default Re: New Si springs and New Civic springs?? (DC5 03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5 03 &raquo;</TD></TR><TR><TD CLASS="quote">
Yup.
Stock: 248 front 440 rear
Tein: 157 front 291 rear
Old Mar 25, 2004 | 11:26 AM
DC5 03's Avatar
Yup.
Tein: 157 front 291 rear</TD></TR></TABLE>
Ewwww, that's horrible. I now feel your pain even more. I had no idea they were that much softer. Downgrade
Old Mar 25, 2004 | 12:04 PM
Only Em2 on H-Tech's Avatar
the springs will work on the Em2 chassis. The rate on the teins are probably due to the obesity of the Ep3..So i think puttin the ep3 springs on a coupe would be a stiffer ride
Old Mar 25, 2004 | 12:22 PM
jaydub's Avatar
Default Re: (Only Em2 on H-Tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Only Em2 on H-Tech &raquo;</TD></TR><TR><TD CLASS="quote">the springs will work on the Em2 chassis. The rate on the teins are probably due to the obesity of the Ep3..So i think puttin the ep3 springs on a coupe would be a stiffer ride</TD></TR></TABLE>
Spring rate is more complex than just the car's weight. Your car is no lightweight either.
2,579 vs. 2,744
Old Mar 25, 2004 | 02:59 PM
WhatItDo's Avatar
Default Re: (jaydub)
thanks guys... sounds too complicated... ill just tell him not to do it
Old Mar 25, 2004 | 11:15 PM
03ephatch's Avatar
Default Re: (Moogen)
lol. i've been using the tanabe df210's meant for the em2 for 8 months. getting bouncy. that's another example why you should think twice about using a part meant for anither car. my o2 cents. leason learned. although for $120 brand new, who could pass that up?
Old Mar 26, 2004 | 12:31 PM
Boilermaker1's Avatar
The lengths are different by enough that the drop won't be even. But if you're asking if they'll fit, then yeah, they'll fit. It just doesn't look right.
&lt;---- Learning the lesson right now... EP3 JICs in an EM2, D17 doesn't weigh as much as a K20, front springs too stiff. Oh well, its fixable for pretty cheap.
om_youssef
Honda Civic (2006 - 2015)
May 23, 2018 06:05 AM
zerovandez
Suspension & Brakes
Feb 18, 2009 07:44 AM
taddaceous
Honda Civic (2001 - 2005)
May 4, 2008 04:02 PM
jit01
20
Mar 23, 2007 12:18 PM
J.R.
Aug 24, 2002 05:20 PM
