what intake manifold
what intake manifold would you h-t members recomend for a b16a2 .... im doing a
search and i think i want the skunk 2 but what is this i hear that there is some
type of way the drilled the inside of it and u have to go in and sand it down or
somthing ??? is this true?
skunk2 intake manifold is a nice manifold.. what do you plan on doing with the car? keeping it NA, boost or supercharger?? since you have a b16 you can also look at getting an OEM ITR manifold, it will bolt onto your b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid94Si »</TD></TR><TR><TD CLASS="quote">skunk2 intake manifold is a nice manifold.. what do you plan on doing with the car? keeping it NA, boost or supercharger?? since you have a b16 you can also look at getting an OEM ITR manifold, it will bolt onto your b16</TD></TR></TABLE>
Might as well just get the skunk2, modeled after the ITR, and it's a little bit cheaper depending on how much you search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B16a2 »</TD></TR><TR><TD CLASS="quote">
Might as well just get the skunk2, modeled after the ITR, and it's a little bit cheaper depending on how much you search.</TD></TR></TABLE>
The ITR manifold is much cheaper.
And yes you can "port and polish" your IM. It will basically be the same as a skunk2 then.
ive seen some ITR manifolds go for a lot cheaper then skunk2 manifolds
