help i am throwing cel code 23
Old Mar 25, 2004 | 07:35 AM
allmotorteg_96's Avatar
Default help i am throwing cel code 23
I did a search didnt find anything for cel code 23 which i belive is a knock sensor. I am runing a ls/vetc so i dont have a knock sensor. I was told there was a way to ground it out any help would be greatly appreciated.
Old Mar 25, 2004 | 09:00 AM
4U2NV's Avatar
Default Re: help i am throwing cel code 23 (allmotorteg_96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 &raquo;</TD></TR><TR><TD CLASS="quote">I did a search didnt find anything for cel code 23 which i belive is a knock sensor. I am runing a ls/vetc so i dont have a knock sensor. I was told there was a way to ground it out any help would be greatly appreciated. </TD></TR></TABLE>
That grounding **** doesn't work... Tried it already... Only way to remove the code is to install a knock sensor into your alternator bracket, or get some kinda fuel management i.e. Hondata and disable it...
Old Mar 25, 2004 | 09:05 AM
SuzukaBlueAP2's Avatar
Default Re: help i am throwing cel code 23 (4U2NV)
what ecu are you running ?
Get yourself a P28 and your problem will be solved. Other wise, install a knock sensor, or get an engine management that will allow you to disable it
Old Mar 25, 2004 | 09:31 AM
Default Re: help i am throwing cel code 23 (ScreaminTeg)
i am running the p61
Old Mar 25, 2004 | 10:43 AM
what ECU is the P61 from ? Is that the 92-93 GS-R ECU ?
I think it is....
But yeah, if you can, get a hola of a P28 ECU. Since it appears you are OBDI, keep it to an OBDI ECU also. I am pretty darn sure that will solve your problem.
If you know anyone that has one, you can always try it out then before you bought one.
Old Mar 25, 2004 | 11:47 AM
thanks for th help guys
terplaygroun_dc2
Oct 23, 2008 09:38 AM
oranginal
Jul 6, 2006 02:17 PM
B16CivicEX
Jul 3, 2006 04:58 PM
DumpedSi
Jul 12, 2003 05:51 PM
Sachmo
Jun 10, 2002 01:23 AM
