NO SPARk
Old Mar 25, 2004 | 06:53 AM
c1civic's Avatar
Default NO SPARk
ok im doing an h22 in my hatch everything is done, engine is in , but there is no spark. the ecu works, cause i treid it in my dx, and it started right up. my fuel pump primes when i turn the key to on, so iguess its not my fuel pump or main relay. the dizzy is getting power. we took the cap off, and the inside of the dizzy spins. but still no help, any help would be uch appreicatted, i jsut wasted my whole spring break on just this problem
Old Mar 25, 2004 | 08:23 AM
Sephro's Avatar
Default Re: NO SPARk (c1civic)
Check the connections to the coil. Test to see if the coil is putting out juice.
Old Mar 25, 2004 | 08:25 AM
c1civic's Avatar
the col is brand new, and there is power gonig to the coil, this is also teh 2nd dizzy we have treid
Old Mar 25, 2004 | 09:14 AM
@ries's Avatar
Default Re: (c1civic)
Make sure all the engine grounds are hooked up properly. Like the one on the thermostat housing or tranny. The problem might just be a silly thing like that.
Old Mar 25, 2004 | 09:20 AM
c1civic's Avatar
will check that first hing tomorrow, im off to work now, thanks
Old Mar 25, 2004 | 09:45 AM
Sephro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">the col is brand new, and there is power gonig to the coil, this is also teh 2nd dizzy we have treid</TD></TR></TABLE>
New things don't always work.... I would check to make sure that you are getting voltage out of the coil.
But yeah check the grounds.
Old Mar 25, 2004 | 10:28 AM
c1civic's Avatar
i jsut glancedbefore i left my house, but i do have a thermostat housing ground. Did not see a tranny one..can i jsut run that from any bolt......or where would a tranny ground usually be
Old Mar 25, 2004 | 10:33 AM
prelittlelude's Avatar
make sure that where the coil bolts up, that those are tight, those bolts are part of the circuit, they are a special anti corrosion bolt. just something to check on.
Old Mar 25, 2004 | 10:51 AM
Sephro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">i jsut glancedbefore i left my house, but i do have a thermostat housing ground. Did not see a tranny one..can i jsut run that from any bolt......or where would a tranny ground usually be</TD></TR></TABLE>
The ground on the tranny is the main ground... if you don't have that then.... it should be right below the starter... or maybe it's off to the side. It goes from the - battery terminal. Try adding an aditional ground wire from one of the bolts near the distributor to the frame. Make sure you get good contact.
Old Mar 25, 2004 | 08:30 PM
c1civic's Avatar
hooked up another tranny ground, still nothing
Old Mar 25, 2004 | 08:33 PM
accord387's Avatar
does the motor try and turn over and doesnt? or do you turn the key and nothing happens?
Old Mar 26, 2004 | 04:58 AM
c1civic's Avatar
the motor turns over..it jsut wont saprk
Old Mar 26, 2004 | 09:50 PM
accord387's Avatar
Did you put new plugs and wires in the motor when you got it? a new rotor and cap maybe? when i first got my swap it wouldnt start b/c the wires were bad that came with it
Old Mar 28, 2004 | 05:24 AM
jackstands's Avatar
Are you getting a check engine light, maybe a code 15 which means the distrib. is not gettting signal. Check the signal wire to the main relay. If the relay isn't getting signal, back track the cracked wire. If teh Main relay is getting signal, then the wire running to the distrib. is bad. You can back track the wire or piggyback the starter signal off of something else. A shop manual would be handy. SRS systems receive signal so you can piggy back it, but you have to wire a secondary circuit in order to maintain airbags.
Old Mar 28, 2004 | 07:14 AM
c1civic's Avatar
not throwing any cel's. tomorrow i just picked up my first helms, its like my new bible. but hopefully with this we will be able to find out just what is wrong
Old Mar 28, 2004 | 10:53 AM
SKDRCR's Avatar
have you tested the ignitor in the dizzy?
Leigh572981
Aug 11, 2011 02:22 PM
tgibson
10
Feb 10, 2010 04:17 AM
NL826
15
Jan 23, 2010 12:22 PM
97_boostedcivic
Dec 10, 2005 07:29 AM
crx_of_fury
10
May 31, 2005 02:04 PM
