Must have's for installing JRSC
Old Mar 24, 2004 | 11:32 PM
Luchini's Avatar
Default Must have's for installing JRSC
I recently purchased a JRSC and am calling on all Luders for advice on what to install along with it. The only mods I have are AEM short ram and a Greddy exhaust. Here is my list of upgrades when I install it any other suggestions are welcome
1. Stronger Clutch
2. Hondata or any other tuing equipment
3. Boost gauge
4. Upgraded pulley.
Old Mar 24, 2004 | 11:51 PM
SPAWN01's Avatar
Default Re: Must have's for installing JRSC (Luchini)
What year is your lude?
Old Mar 24, 2004 | 11:56 PM
Monkey Fing a Coconut's Avatar
return/sell it, get a turbo instead, read the horror on the hybrid forum about jrsc....
Old Mar 25, 2004 | 12:01 AM
SPAWN01's Avatar
Default Re: Must have's for installing JRSC (twistedbydezign)
I agree with twisted. JRSC's are a dead end. Go turbo. Hondata s200 with boost and a p7s.
Old Mar 25, 2004 | 01:47 PM
Kal's Avatar
Kal
Default Re: Must have's for installing JRSC (SPAWN01)
if you still want to jrsc, it's good to get a good header and a good exhaust system.
Old Mar 25, 2004 | 01:50 PM
TimeRacer's Avatar
Roots systems are better on cars that actually need to go down to 3000 RPM's and back up again. Turbos are great for going straight.
Old Mar 25, 2004 | 02:03 PM
Luchini's Avatar
Its for a 2000. I got a really good deal on it which is why I got it over a turbo. I got it for about half the cost of a pre made turbo kit.
Old Mar 26, 2004 | 01:13 PM
Notorious869's Avatar
i have a '00 lude w/a jrsc, greddy evo exhaust, hp header, no cat no resignator, and aem cai, and that personally i think is a good setup, i dyno @ 241 & 197 lb/ft so you be your own judge
Old Mar 26, 2004 | 01:46 PM
Kal's Avatar
Kal
Default Re: Must have's for installing JRSC (Notorious869)
you might want to get a fpr and fuel rail also. new plugs, wires, usual stuff...
Old Mar 31, 2004 | 01:24 AM
Luchini's Avatar
hey notorious how many psi are u running and do you have it tuned at all? how long have u had it for to?
Old Mar 31, 2004 | 03:14 PM
redsidriver's Avatar
i would recomend a hondata intake manifold gasket . ive had my sc on for almost a year and just ordered the gasket so ima have to go through the trouble of taking it apart again juts to put in new gasket.fuel pump fpr fuel rail hmmm and maybe a hondata if u can afford it along with some new injectors . if u have the money at the moment.
Old Mar 31, 2004 | 04:24 PM
sharkcohen's Avatar
Default Re: Must have's for installing JRSC (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">you might want to get a fpr and fuel rail also.</TD></TR></TABLE>
Neither is necessary, waste of money.
Old Apr 1, 2004 | 01:22 AM
Luchini's Avatar
Default Re: Must have's for installing JRSC (sharkcohen)
Hey Shark how many psi are you running? You have it tuned at all?
Old Apr 1, 2004 | 04:56 AM
JDogg's Avatar
keep in mind that if you do hondata on a prelude you will have to get an obd1 distributor and wire it in. we ran into this problem with a customer car and opted to put an aem ems on it so the factory wiring wouldnt have to be changed.
get some 450cc injectors and some real engine management with that thing. you should see 240-250hp on 6psi. the last one i did with boost peaking at 11psi at 4000 rpms and then droping to 6 at about 7000 made 215tq and 247hp. and that was tuned for saftey, not power. it made for a fun car,.
Old Apr 1, 2004 | 07:59 AM
the_eyecon's Avatar
I agree, Turbo is for drag, IMO I think SC is best for Auto-X, turbo isn't my thing, too much time money tuning time and other things. I would rather run a decent set up with a JRSC at 6-7psi and get a decent amount of horsepower, not everyone needs to be the fastest prelude on the face of the earth, waste of money if you ask me, turbos that is.
Old Apr 1, 2004 | 09:37 AM
sharkcohen's Avatar
Default Re: Must have's for installing JRSC (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind that if you do hondata on a prelude you will have to get an obd1 distributor and wire it in.</TD></TR></TABLE>
Not true. OBDII ludes do NOT need an OBDI distributor to run Hondata.
Old Apr 1, 2004 | 09:41 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">Hey Shark how many psi are you running? You have it tuned at all?</TD></TR></TABLE>
I'm running the stock 6 psi. It's been street tuned by myself. I was running the 9 psi pulley, but the ultra high intake temps make it too much of a headache, and the gains are very minimal. 9 psi isn't worth it, I don't recommend it. It is too far out of the M62's efficiency range.
Old Apr 1, 2004 | 10:04 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Not true. OBDII ludes do NOT need an OBDI distributor to run Hondata.</TD></TR></TABLE>
then how the hell do you make it work? we were using a chipped ecu with crome and kept getting a code 9.. cyp sensor, that sensor is not in the distributor.
we were logging over 200 deg intake temps with the 9psi pully spiking to 11+.. way too damn hot
Old Apr 1, 2004 | 11:22 AM
sharkcohen's Avatar
I'm not sure what issue you were having running an OBDI ecu on an OBDII H22, but it is a fact that swapping distributors isn't necessary. It's plug and play with an OBDII-&gt;OBDI harness. What OBDI ecu were you trying to use, and was it on a 5th gen prelude, or another car?
Yup, I was seeing over 200 degree IATs with the "9" psi pulley as well. I was having to pull way too much timing to stave off detonation. I find it interesting that people running the stock 6 psi have made up to 240 whp, while I've never seen a 9 psi setup make more than 260. Not worth the headache, IMHO.
Old Apr 1, 2004 | 11:45 AM
JDogg's Avatar
it was a 97 prelude with a obd2a to obd1 jumper and a p28 ecu.
i think it might be an issue with the 97-98 prelude.. 96-97 accords are the same way, they only have 2 sensors in the distributor, not 3 like everything else. i have talked to a few other people that have run into the same problem
Old Apr 1, 2004 | 11:59 AM
sharkcohen's Avatar
Never heard of an issue on any year 5th gen lude, and people have been doing this for several years now. Very odd. Possibly a problem with the harness that was used?
Old Apr 2, 2004 | 12:07 AM
Luchini's Avatar
Whats a good header to run? Kamakazi's i heard.
Old Apr 2, 2004 | 01:08 AM
are kamakazi headers carb legal?
cold_heart51
Jan 29, 2006 07:52 PM
Aquaman
Jul 28, 2003 07:20 PM
Thrillhouse
Sep 8, 2002 07:21 PM
MacLeanQuinn
Oct 10, 2001 07:41 AM
