Help!! just swaped Si Sohc, Problems....
Old Mar 24, 2004 | 10:45 PM
stpcivicguy's Avatar
Default Help!! just swaped Si Sohc, Problems....
Help! I just swapped in my Si Sohc engine into my EG coupe and now the reverse lights won't come on when I throw it into reverse.
I checked 1156 reverse blubs & it was fine.
Is there a button or switch that turns it on when you throw it into reverse? That might be going bad but can't locate it.
Damn I can't see **** when I reverse at night, almost hit another car in parking lot. I need to get this fixed soon.
Old Mar 24, 2004 | 10:47 PM
94SiHatch's Avatar
Default Re: Help!! just swaped Si Sohc, Problems.... (stpcivicguy)
you missed a plug on the back of the tranny. simple fix. Find the connector on the tranny thats not plugged in, then find the correct plug on the harness...all done.
Old Mar 24, 2004 | 11:43 PM
E-brake or Handbrake's Avatar
Default Re: Help!! just swaped Si Sohc, Problems.... (94SiHatch)
Bump for a picture of what to look for. My car's reverse bulb doesn't light up as well.
Old Mar 25, 2004 | 02:25 AM
2lua's Avatar
that plug is on the top of the transny close to the rear mount.
Old Mar 25, 2004 | 07:19 PM
d15nonvtec's Avatar
Default Re: (2lua)
could be the connector too, mine went bad and i just cut out the connector and soldered and heat shrinked the wires together, lasted a long time, till i swapped motor/trans
TMC_EF
Jul 14, 2008 07:19 PM
TheSecondMe
Sep 7, 2005 10:28 AM
phokemon
Oct 31, 2004 06:19 AM
96cx
12
Oct 4, 2004 03:34 AM
EL-Driver
Apr 13, 2002 06:35 PM
