are all bseries fuel rails interchangeable?
Old Mar 24, 2004 | 10:09 PM
DefiantGSR's Avatar
Default are all bseries fuel rails interchangeable?
like the title says, are all b series fuel rails interchangeable? im thinking yes.
does it matter if the fuel rail is from a obd0,1,2 car? thanks
Old Mar 24, 2004 | 11:03 PM
W.O.P.'s Avatar
Default Re: are all bseries fuel rails interchangeable? (DefiantGSR)
may i ask why?
Old Mar 25, 2004 | 01:19 AM
riceball777's Avatar
yes they are all interchanable
Old Mar 25, 2004 | 03:41 AM
Xsi's Avatar
Xsi
Default Re: are all bseries fuel rails interchangeable? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">yes they are all interchanable</TD></TR></TABLE>
Are you sure? I have heard for example that a B16a1 fuel rail won't work with an itr manifold
Old Mar 25, 2004 | 04:31 AM
96 Ls lnTeG's Avatar
Default Re: are all bseries fuel rails interchangeable? (Xsi)
Not to Thread Jack are FUEL RAILS LEGAL in Cali for smog??
Old Mar 25, 2004 | 08:37 AM
Devlins 91LS's Avatar
Default Re: are all bseries fuel rails interchangeable? ([TODA R] 2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [TODA R &raquo;</TD></TR><TR><TD CLASS="quote"> 2000]
No they are not.
They do not mount the same. </TD></TR></TABLE>
Ok, well they all MOUNT the same, but the fpr on some ls fuel rails is in a diff spot than on the vtec ones, which makes it hit the air flow sensor on your #1 cylinder.
Old Mar 25, 2004 | 01:25 PM
DefiantGSR's Avatar
Default Re: are all bseries fuel rails interchangeable? (dohc VTEC eaaater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc VTEC eaaater &raquo;</TD></TR><TR><TD CLASS="quote">may i ask why?</TD></TR></TABLE>
i plan to make myself some ITBs. some guy is selling na 1990 b18a fuel rail for almost nothing and i wans't sure it'd fit. which fuel rails would work w/ a GSR engine? just vtec fuel rails? thanks
Old Mar 25, 2004 | 01:29 PM
DefiantGSR's Avatar
When I say mount, I mean mounting to the intake manifold.
Sure, they all fit.. but they aren't all securely bolted down, thus making it "not fit"
I would never run a motor with it not bolted down properly, so why even tell a person that'll it fit and give them the chance of running it improperly bolted down.
Not having it bolted down will lead to an engine fire very quickly. </TD></TR></TABLE>
thanks toda R for clarifying everything
Old Mar 25, 2004 | 08:44 PM
deepgreengsr's Avatar
I know i have a b18 rail on a b16. They are the same. I dunno bout vtec ones. just buy it and check it out.
ballerchild
10
Mar 17, 2007 11:16 PM
lsvtecvx
May 30, 2005 05:17 PM
GruvyTune
Feb 17, 2005 11:27 AM
mrcrimane
Aug 9, 2003 11:43 AM
