I misshifted in my R tranny dude...help
This tank of gas i was currently on.. i wasn't shifting over 3k rpms to see how miles i can get out of my 10gallon cx. I was already at 220miles and had a 1/3 to go...
but then i saw this mustang gt, new body style..bullet wheels. I raced him froma 2nd punch below vtec and pulled on him. As i was trying to shift into 4th..it didnt go. It was stuck...so i pulled harder and for some reason it went into 2nd
rpms raised car engine-braked, i quickly popped it out of gear/pushed the clutch in.
immediatly after...my car wouldnt go into any of the gears. the motor sounded fine as far as ticking went. I pulled into a gas station (rolled in) and tried to get my car into gear...it didnt. i revved the motor slowly and at 3.5k rpms... even less like 1.5k rpm... the motor shaked.. i could feel it through the steering wheel and the shifter. After a lot a force, i finally managed to get into 3rd. getting it into the gears were hard.. some times id have the rev the motor a little, and it would slip in.
do i need a new clutch/pressure plate? what is causing the vibration. Is the motor fine?
on me
BTW, i have a 96spec jdm itr swap
<FONT SIZE="3">EDIT: VIDEO LINK ADDED AT BOTTOM!!</FONT>
Modified by John Kerry at 6:33 PM 3/25/2004
Modified by John Kerry at 7:20 PM 3/25/2004
on meBTW, i have a 96spec jdm itr swap
possibley a shifter fork... also could be the clutch bolts coming loose... that same thign happened to me too and then found out that whoever installed my clutch forgot to put on loctite on the clutch bolts, so they eventually just started to sget loose and then no more pressure so the clutch ouldnt put my gears in gear, haha
unfortunatly, it could be any number of things, Your going to have to pull your tranny and start from there, check the clutch and flywheel first, if everything is ok there, dig into the tranny, or have someone that knows what they are doing look into it. I would guess shift forks, or broken clutch.
my tranny locked me out last week ripped it apart and the clutch was shot to ****, the springs in the hub were ready to fall out and the pressure plate was all jacked
turn the car off and try to put it into the gears if u can put them in with the car off it's prob just the clutch
actual disc itself?
that means i need to basically get a new clutch since it comes witha pressure plate.
CM stage 3 w/ kaiten superlight flywheel
could i run the cm stage 3 with my stock itr flywheel?
how IS my stock flywheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">unfortunatly, it could be any number of things, Your going to have to pull your tranny and start from there, check the clutch and flywheel first, if everything is ok there, dig into the tranny, or have someone that knows what they are doing look into it. I would guess shift forks, or broken clutch.</TD></TR></TABLE>
Best advice.
Guessing won't help - pull the tranny out and see for yourself bro.
Best advice.
ya pull it and check everything before u just go dump 490 dollars on a CM stage 3. Mine just went out and i just ordered that exact clutch it should be in by saturday so ill let u know how i like it, but it will work with the stock flywheel as long as it's machined
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marlboroRED »</TD></TR><TR><TD CLASS="quote">survey says bent valves in your head making your motor shake
Thats what im guessing my friend did the same thing.
</TD></TR></TABLE>Thats what im guessing my friend did the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda »</TD></TR><TR><TD CLASS="quote">
Thats what im guessing my friend did the same thing.</TD></TR></TABLE>
lol mine too in 96 gsr lol no springs/retinors
ive done it w a b16 stocker (4 or 5 times i was a noob and put into 2nd untill 10,500 no bent valves and no blow maby im lucky!(that was three years ago) lol
I dont think its my valves? i dont hear ticking?
most people are saying the vibration is being caused by my pressure plate.
so since my pressure plate needs to be replaced... might as well replace my clutch.
what can i do to see if its my valves. Can i listen fo it when i start my car in idle and rev it from the throttle?
Took a video of it.. can you make out anything?
<FONT SIZE="5">***RIGHT CLICK SAVE AS***</FONT>
Modified by John Kerry at 6:26 PM 3/25/2004
Will it go into gears with the motor off? If so, the clutch disk springs may have exploded, causing it to be constantly engaged. This happened to me in my old crx and I had to drive w/o a clutch pedal...and having to start the car in 1st gear every time I stopped.
sorry. I was being lazy. I bet your clutch disk springs blew out, locking the disc into place. It would probably be good to get a new disc, pplate, and flywheel (or at very least resurface your existing. I am almost sure this is what happened to yours.
anybody watch the video?
found the CM stage 3 for $409 plus 30 dollars shipping
how much will it cost to resurface a flywheel? i never really familiarized my self on how much it costs to do such a thing
watch the video people... anyone thin the flywheel may have messed up?
i can't open it up myself.. waiting to goto shop when clutch comes in
anyone know the price on resurfacing a flywheel?
clutch master stage 3 was put in friday and i LOVE IT it makes the car so much easier to drive, and the reason my car wouldn't go into the gears is because the little pieces of metal that held the springs in the hub tore out and the springs were able to leave the hub, locking up the pressure plate from being able to relase the disc from the flywheel and ya it's like 20-50 bux to get the fly wheel re-serfaced the spec sheet from CM said to make it .110'' if i remember correctly, just call and make sure
i just watched the video it's nothing in ur tranny it's doing the EXACT same thing my did if u pull the clutch off i'll bet the springs in the hub are all fucked up if it was ur tranny it would be howling and making all all kinds of weird sounds when u are trying to put it into gear
