Button for A/C on EG 92-95 Civic
Old Mar 24, 2004 | 08:17 PM
VtecBio009's Avatar
Default Button for A/C on EG 92-95 Civic
in relation to those civics without the A/C..the A/C button is covered up.
i am about to buy the climate control section from a civic that has the a/c button still covered so...
since my civic has A/C do i simply remove the cover from the A/C button when swapping in a new climate control?
Old Mar 24, 2004 | 08:19 PM
BauleyCivic's Avatar
Risky Business
Default Re: Button for A/C on EG 92-95 Civic (VtecBio009)
why are you buying a new climate control? sounds like you'd have to swap the entire unit over...i'm confused
Old Mar 24, 2004 | 08:20 PM
mattEG's Avatar
By covered up do you mean thats its not there? Because there isn't one on my car.
Old Mar 24, 2004 | 08:24 PM
VtecBio009's Avatar
Default Re: Button for A/C on EG 92-95 Civic (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">why are you buying a new climate control? sounds like you'd have to swap the entire unit over...i'm confused</TD></TR></TABLE>
i AM getting the entire unit...a climate control. getting a new one because the hot/cold slider is kinda not working.
but do you know how they a/c button is on the far right, the one i'm looking to get has a plastic piece covering that up...and if i recall correctly, i thought all civics came with the a/c button, but if your car didnt come with it..it came with a plastic piece covering that button up.
help please
Old Mar 24, 2004 | 08:25 PM
Risky Business
whats wrong with the slider? the slider is connected to a cable that pulls the heater control back and forth...your problem may not be with the climate control unit...
Old Mar 24, 2004 | 08:30 PM
VtecBio009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with the slider? the slider is connected to a cable that pulls the heater control back and forth...your problem may not be with the climate control unit...</TD></TR></TABLE>
i think it may be the slider, it may be broken or something. hmm, maybe i can check it out.
how do i safely remove the unit??
Old Mar 24, 2004 | 08:32 PM
Risky Business
https://honda-tech.com/zerothread?id=661308
Old Mar 24, 2004 | 08:37 PM
VtecBio009's Avatar
thanks man
holy sniper!! thats a lot of **** to do just to get to the climate control
lastdaze
Apr 24, 2007 09:16 AM
SIcivicHATCH
May 18, 2005 10:11 AM
.BigSexy
Audio / Security / Video
Aug 2, 2004 09:17 AM
Beeline
Apr 22, 2002 08:49 AM
Petah
Apr 18, 2002 07:11 AM
