spring rates
Old Mar 24, 2004 | 07:39 PM
Exclusiv3's Avatar
Default spring rates
On ground control coilovers how can you tell what the spring rates are
Old Mar 24, 2004 | 07:46 PM
JFG Kevin's Avatar
Default Re: spring rates (Exclusiv3)
i read that you can customize your own spring rate...but not sure if that's true...(plz clear this quiestion up fo meh too)
Old Mar 24, 2004 | 11:50 PM
DC2*Integra's Avatar
Default Re: spring rates (aznstyler119)
i heard u can also. try asking the people that sells them, like the sponsors here
Old Mar 24, 2004 | 11:57 PM
typeRSXS's Avatar
yes you can get custom ground controls. usually any performance/auto store that sells it has the option to do it
Old Mar 25, 2004 | 05:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: spring rates ([TODA R] 2000)
From what I've seen the regular springs that come w/ the GC Special Editions have a different numbering system than the ERS springs, so you can't go by that to tell the spring rate. The ERS springs have part numbers that reflect the spring's free length, diamter, and rate, i.e. 700.0250.0450 or something to that effect, means the spring is 7" long, 2.5" diameter and has a rate of 450 lb/in.
Old Mar 25, 2004 | 06:49 AM
Exclusiv3's Avatar
front=GC200.64.67
Rear=GC180.64.44
Old Mar 25, 2004 | 06:55 AM
Community Builder
See what I mean, those numbers don't follow the normal Eibach Race Spring numbering system, so you can't tell the spring rates from that.
aznriceryder
Suspension & Brakes
Oct 26, 2007 09:37 AM
P@@RB@Y
Suspension & Brakes
Dec 26, 2005 08:38 AM
danmanh22
May 28, 2004 09:02 PM
96 SOHC VTEC
Mar 30, 2003 10:17 AM
Doctor CorteZ
Feb 27, 2002 06:07 PM
