Maintenance question
Old Mar 24, 2004 | 07:26 PM
97JDMAccord's Avatar
Default Maintenance question
I bought a 97 accord with 125000 miles about four months ago. When I got the car I did the usual stuff. Changed the oil (which i keep up on), spark plugs, power steering belt, and wires. I want to change the distributor cap, timing belt, ATF fluid and alternator belt. Should I do everything at once be on the safe side or do one at a time?
Old Mar 24, 2004 | 09:01 PM
KDKane's Avatar
Default Re: Maintenance question (97JDMAccord)
Depends on $ flow
If you have the dough, then do them all. If money is tight and the timing belt has not been done, then that is the priority.
Old Mar 24, 2004 | 09:40 PM
sinister2c's Avatar
Default Re: Maintenance question (KDKane)
With the timing belt off and drive belts, do the water pump and main oil seal. Its about $50 in OEM parts.
Old Mar 25, 2004 | 12:23 AM
Spider Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97JDMAccord &raquo;</TD></TR><TR><TD CLASS="quote">I bought a 97 accord with 125000 miles about four months ago. When I got the car I did the usual stuff. Changed the oil (which i keep up on), spark plugs, power steering belt, and wires. I want to change the distributor cap, timing belt, ATF fluid and alternator belt. Should I do everything at once be on the safe side or do one at a time?</TD></TR></TABLE>
dang a 97 with 125k miles.
I thought my 93 with 130k miles was high.
Old Mar 25, 2004 | 04:14 AM
vabchaccord's Avatar
Default Re: Maintenance question (Spider Man)
well with the average car getting 15k/year, that's about 120k for a 97, my 97 has 130k.
dlstech
10
Feb 26, 2012 05:36 PM
afreeclimber
Apr 9, 2008 08:18 PM
Nosepicker
Jan 12, 2008 06:48 PM
hkreplica
Nov 29, 2007 02:17 PM
quikrpm'z
Feb 19, 2003 03:14 AM
