D16z6 Del Sol All Messed Up..... = (
Old Mar 24, 2004 | 05:29 PM
DelSolSi93's Avatar
Default D16z6 Del Sol All Messed Up..... = (
Ok just when I think things are going great my CEL comes on, its a TPS code so to make a long story short I got a good TPS sensor and had my trusted shop replace it. Car is fine starts right up (now remember the car has been turned off for a while and is pretty much cold). I start driving and it does fine until the motor warmed up to normal and whenever I come from driving to a full stop (like a stop light) the idle stubles WAY down to like 450-500rpm and then stalls, but only when its warmed up, if its cold or right after I start driving it, its fine. It will not start back up for a few seconds, it turns over and will kinda start to catch and then stuble and quit again. I took it back and checked the sensor, wiring, everything seems fine. I upped the idle a little bit too and that seemed to fix it for like a day and now its doing it again, but no CEL, can anyone help me??!? I need my car for work and I cant get around so I need to get this fixed in a hurry. I have no idea whats wrong because it would kind of stumble from time to time and then my gas mileage went to crap and then the TPS CEL came on so I thought that was the problem and now that its replaced and all wiring and sensors/install is good it got worse? Whats going on here?
Old Mar 24, 2004 | 05:35 PM
Bakeoff's Avatar
Default Re: D16z6 Del Sol All Messed Up..... = ( (DelSolSi93)
sounds like they didn't calibrate the tps....
Old Mar 24, 2004 | 05:41 PM
DelSolSi93's Avatar
Default Re: D16z6 Del Sol All Messed Up..... = (Bakeoff)
Im pretty sure its calibrated correctly they even tried re-doing it a second time
Old Mar 24, 2004 | 05:55 PM
toolowsol's Avatar
Default Re: D16z6 Del Sol All Messed Up..... = (DelSolSi93)
check it yourself to be sure.
Old Mar 24, 2004 | 06:04 PM
DelSolSi93's Avatar
Default Re: D16z6 Del Sol All Messed Up..... = (toolowsol)
not to sound lame, but how exactly would I go about doing that
Old Mar 24, 2004 | 08:07 PM
DelSolSi93's Avatar
bump
Old Mar 25, 2004 | 05:53 AM
DelSolSi93's Avatar
Anyone?! Ive got to get to work and I cant keep it running
Old Mar 26, 2004 | 09:00 PM
DelSolSi93's Avatar
Default Re: (DelSolSi93)
ok last try guys, can anyone help me? I also changed the igniter and its somewhat better but the idle is still all over the place it dips to like 500rpm, goes up to like 900rpm, then to 500, then to 900, stops at 650 then dips, and so on, it keeps doing that pattern, whats the deal here?
Old Mar 26, 2004 | 10:34 PM
kabaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">sounds like they didn't calibrate the tps.... </TD></TR></TABLE>
um yea peter, we changed the form on those tps reports. and if you could get them in by the end of that day thad be great.
Old Mar 28, 2004 | 05:36 PM
DelSolSi93's Avatar
Default Re: D16z6 Del Sol All Messed Up..... = (kabaroo)
ok so sounds like thats the problem, how would I go about calibrating the TPS sensor?
Xathine
10
Aug 27, 2013 08:39 AM
Eddie 70
Feb 20, 2011 08:54 PM
wvudelsol
Dec 26, 2008 08:15 AM
hellbus
Apr 6, 2004 09:50 AM
