Frozen/Seized Lower Spring Seat/Seat Lock on Coilovers
Old Mar 24, 2004 | 05:26 PM
unACCORDInated's Avatar
Default Frozen/Seized Lower Spring Seat/Seat Lock on Coilovers
Thanks to the lovely weather in Ohio and the liberal use of road salt my recently removed Tein SS Coilovers have seized up (Lower Spring Seat/Seat Lock). Any ideas for looseing up the grit and salt that has the threads locked? Is there possible something I can soak it in. I am at first going to try just soaking them in some hot water or something, but is there something else I could try?
Thanks.
Old Mar 24, 2004 | 07:15 PM
onePOINTsix's Avatar
Default Re: Frozen/Seized Lower Spring Seat/Seat Lock on Coilovers (unACCORDInated)
send them back and get a new one, they are guaranteed so they should send you a new one, not sure tho
Old Mar 25, 2004 | 03:44 AM
Default Re: Frozen/Seized Lower Spring Seat/Seat Lock on Coilovers (Sideout)
Well the issue is not with the overall operation of the unit, it is due to dirt and crap sitting on the threads. So I would be shocked if any coverage would be provided for this.
Old Mar 26, 2004 | 05:28 AM
Well I soaked them in some hot water and that helped to dissolve some of the grit, but it really didn't penetrate the dirt as much as I had hoped. Any products that are meant for loosening frozen threads or something that can eat away dirt and grime?
Old Mar 26, 2004 | 07:37 AM
rubix777's Avatar
bathroom and tile cleaners?
Old Mar 26, 2004 | 07:47 AM
slow_dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unACCORDInated &raquo;</TD></TR><TR><TD CLASS="quote">Thanks to the lovely weather in Ohio and the liberal use of road salt my recently removed Tein SS Coilovers have seized up (Lower Spring Seat/Seat Lock). Any ideas for looseing up the grit and salt that has the threads locked? Is there possible something I can soak it in. I am at first going to try just soaking them in some hot water or something, but is there something else I could try?
Thanks.</TD></TR></TABLE>
My friend and I went through this with his skunk2 sleeves.
We did them on the car; sprayed liquid wrench and wiped down with a rag and brush. This cleaned most of the crap out of the threads, and allowed us to move the perch a little. We would then clean the portion of the exposed thread, and continue to move the perch in this manner.
Used about 1 can of liquid wrench per side.
It was an enormous pain in the ***; a couple of hours of smelly, dirty work.
But it beats buying new suspension bits
Old Mar 26, 2004 | 09:26 AM
Default Re: Frozen/Seized Lower Spring Seat/Seat Lock on Coilovers (slow_dx)
Thanks to all for input. Looks like Saturday will be the marathon cleaning day.
Hatchoo
Suspension & Brakes
Nov 1, 2005 09:58 AM
diluted
Jul 22, 2004 01:39 PM
97ITR217
May 2, 2003 07:01 AM
DSeriesBeeKilla
Mar 7, 2003 03:45 PM
Toda Party
Dec 22, 2001 12:26 AM
