Total timing. What is everyone running?
Old Mar 24, 2004 | 05:17 PM
ImAcracker's Avatar
Loved
Default Total timing. What is everyone running?
I did a search and found a little bit of info. But not a whole lot. Most of what I found was not on a B16A (which Im running). Im wonderng what everyone is runing for there total timing. Currently Im running ~18 to 19 deg on .5bar. From what Ive read so far I think I can add probably another 2 or 3 degrees safely. Can you all please list your basic setup and total timing? And your Compresion ratio would be really helpfull. Thanks for anyone that responds.
My basic setup is t3/t4 on a stock B16A running .5bar.
Old Mar 25, 2004 | 04:35 PM
ImAcracker's Avatar
Loved
Default Re: Total timing. What is everyone running? (ImAcracker)
Old Mar 25, 2004 | 04:45 PM
grndcont's Avatar
i'm gona try 22' up top @ around 16 psi.
99B16Si's Avatar
fully built b20/vtec 9:1 compression 15psi 93 octane 14.5-degrees and 11:1 a/f ratio...tuned with aem ems
i like to keep things safe
oh and my previous motor(same setup) melted a piston with 11.3:1 a/f ratio 17 degrees of timing, 19-20psi, and 93 octane(supposedly). just goes to show u that even bullet proof motors can blow too
Old Mar 25, 2004 | 04:47 PM
ndogg's Avatar
Default Re: (99B16Si)
i think that it would be better to run a more timing. you will have rediculously hot egt's with that much retardation y0.
Old Mar 25, 2004 | 04:53 PM
99B16Si's Avatar
Default Re: (ndogg)
id rather have slightly higher egts than nasty detonation...trust me i know from experience... a few degrees retarded up top is not gonna hurt anything. now maybe if i had it at like 10degrees, than yes i would agree with you
Old Mar 25, 2004 | 05:11 PM
ndogg's Avatar
with 84mm bore and low compression pistons i think others will agree you are past the "keeping it safe" point. and into the rediculous amount of retard arena.
Old Mar 25, 2004 | 08:16 PM
kpt4321's Avatar
10 psi, 93 integra B18A, 14b: 20 degrees peak. That's with ZERO knock on the J&S safeguard, so I may add a little bit more in to see what happens.
Old Mar 25, 2004 | 08:24 PM
turbolsintegra26's Avatar
Default Re: (kpt4321)
B18B stock internals & compression 20 deg @ 10.5 psi 11.5:1 A/F run by hondata, and only very little street tuning. No signs of detonation or knocking & stable EGT's.
Old Mar 25, 2004 | 08:28 PM
maxpsi's Avatar
Default Re: (Turbointegra22)
B16A2 stock internals & compression 27 deg @ 11psi 11.4:1 A/F run by Hondata + P28.
Old Mar 25, 2004 | 08:35 PM
ITSTOCK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">10 psi, 93 integra B18A, 14b: 20 degrees peak. That's with ZERO knock on the J&S safeguard, so I may add a little bit more in to see what happens.
What are you guys using for fuel management Kyle?
Mase's Avatar
Default Re: (maxpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">B16A2 stock internals & compression 27 deg @ 11psi 11.4:1 A/F run by Hondata + P28.</TD></TR></TABLE>
i sure hope your base timing is retarded, cuz 27 is way too much, that motor wont last long w/ 27 degrees of total timing on that high of compression and boost levels
Old Mar 25, 2004 | 08:43 PM
maxpsi's Avatar
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
i sure hope your base timing is retarded, cuz 27 is way too much, that motor wont last long w/ 27 degrees of total timing on that high of compression and boost levels</TD></TR></TABLE>
Found that out after cracking all ringlands. The motor is being rebuilt with CP 9:1 pistons, Eagle rods, blockguard, and some quality machine work. Then I am getting it tuned by Ed at Balanced Performance.
Old Mar 25, 2004 | 08:51 PM
BlackKnight7's Avatar
Default Re: (ITSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">
What are you guys using for fuel management Kyle?</TD></TR></TABLE>
It's my car and it's using uberdata, at 10 psi...and it outpulls his talon from a roll, he's not happy.
Jake D.
Old Mar 25, 2004 | 08:55 PM
Mase's Avatar
Found that out after cracking all ringlands. The motor is being rebuilt with CP 9:1 pistons, Eagle rods, blockguard, and some quality machine work. Then I am getting it tuned by Ed at Balanced Performance.</TD></TR></TABLE>
who tuned it before?
Old Mar 25, 2004 | 09:03 PM
ITSTOCK's Avatar
Default Re: (BlackKnight7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackKnight7 &raquo;</TD></TR><TR><TD CLASS="quote">
Jake D.</TD></TR></TABLE>
Old Mar 25, 2004 | 09:05 PM
This One's Avatar
are there any dataloggers out there for stock computers?
I really need to see Total timing on my car w/ e-manage
Old Mar 25, 2004 | 11:08 PM
DIRep972's Avatar
Smarter than you
I ran 22deg. @ 12psi w/ 11.5:1 a/f on stock LS motor, planned to try some advance on the dyno but never got around too it.
Old Mar 26, 2004 | 08:11 PM
ImAcracker's Avatar
Loved
Default Re: (tHIS oNE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHIS oNE &raquo;</TD></TR><TR><TD CLASS="quote">are there any dataloggers out there for stock computers?
I really need to see Total timing on my car w/ e-manage</TD></TR></TABLE>
http://www.ecucontrol.com
I think this works for OBDI ECU's. Not sure though. Check it out.
Bump.
Old Mar 27, 2004 | 06:17 PM
ImAcracker's Avatar
Loved
Default Re: (ImAcracker)
Well I added about 2 to 3 degrees. And WOW!!! Night and day diffrence. Im so glad to have the power back that I lost when I went from the Hack to Uberdata. My tune was just too damn conservative I guess. Im currently sitting at about 20.5 total timing now at .5bar. I wonder if I can add even more timing.
Im still curious as to what everyone else is running for their total timing though.
Old Mar 27, 2004 | 06:22 PM
hybrid901's Avatar
10:1 compression, 24degrees@25psi c116
Old Mar 27, 2004 | 06:31 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImAcracker &raquo;</TD></TR><TR><TD CLASS="quote">Well I added about 2 to 3 degrees. And WOW!!! Night and day diffrence. Im so glad to have the power back that I lost when I went from the Hack to Uberdata. My tune was just too damn conservative I guess. Im currently sitting at about 20.5 total timing now at .5bar. I wonder if I can add even more timing.
Im still curious as to what everyone else is running for their total timing though. </TD></TR></TABLE>
Might want to find a way to lower your intake temps more first though. I would also look at a lower temp thermo, also. Good luck, and happy tuning.
Old Mar 27, 2004 | 06:36 PM
ImAcracker's Avatar
Loved
Default Re: (Nid Styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nid Styles &raquo;</TD></TR><TR><TD CLASS="quote">
Might want to find a way to lower your intake temps more first though. I would also look at a lower temp thermo, also. Good luck, and happy tuning.</TD></TR></TABLE>
lol...How did you now my filter is right behind my radiator currently? Ive ordered the piping already though to redo my IC and intake piping. Just waiting for it to come in the mail and have some time off from work.
Old Mar 27, 2004 | 06:41 PM
Nid Styles's Avatar
lol...How did you now my filter is right behind my radiator currently? Ive ordered the piping already though to redo my IC and intake piping. Just waiting for it to come in the mail and have some time off from work.</TD></TR></TABLE>
It's actually very common for people to try higher timing with realizing that you need to drop your intake temps as much as possible to help prevent detonation. Tapping a little hole in your thermo helps a bit too.
Old Mar 27, 2004 | 06:43 PM
ImAcracker's Avatar
Loved
Tapping a little hole in your thermo helps a bit too. </TD></TR></TABLE>]
errr....what does that mean?
