Need camber kit step by step
Old Mar 24, 2004 | 04:48 PM
Prelude94's Avatar
Default Need camber kit step by step
Does anybody here know where I can find a step by step installation guide for installing and anchor bolt camber kit on a 94' prelude Si? I'm chewing up tires like crazy and I desperately need to correct the problem. I have the kit. I'm just not sure how to install it.
Old Mar 24, 2004 | 07:27 PM
92LudeSI's Avatar
Default Re: Need camber kit step by step (Prelude94)
theres two bolts in the engine bay right by the top of the strut tower bar. Your upper control arm will then swing out and its pretty self explanatory from there. Same for the back take out your back seats and there is one bolt there and the other 2 are in the trunk behind the carpeting. Then go and get it aligned and make sure to tell them you have the camber kit so they adjust it.
Old Mar 25, 2004 | 03:56 AM
Behan's Avatar
i know that one manufacturer has instructions on their website, but i can't remember which one. its not spc or ingalls. anyway, here is a pic of how the anchor bolts install on the control arms. its not a step by step, but it's a pretty straightforward install.
just make sure you get an alignment right after installation, good luck.
88crx-si
May 9, 2006 07:22 PM
chestnut_55
Oct 23, 2005 03:24 PM
allmotorEG-SI
Jul 18, 2004 11:33 AM
Steve90HB
Sep 4, 2003 12:47 PM
96whitels
Feb 1, 2002 07:12 PM
