since putting on a new distributor, the starting power is gradually declining
Guest
Posts: n/a
is this a sign of some thing else being wrong.
when i first put the distributor on it started right up. now as the days go on it has to "crank" sometimes. wtf is up with this ****
dude what's up. listen start the car. then move the distributor right and left and listen to how the car works.
if u want more details come to http://www.cb7tuner.com it's noly for 4th generation hondas.
put the same nickname. there are a bunch of philly people there.
the wheel should be at your drivers side, under the alternator pulley, youll see this
Y or V looking thing just popping out... aim the gun down and make sure its aligned right... for 5th gens i think its 15 degrees.. if you dont have access to a gun, shops usually charge 15-20$ to check and set it for you... if you do have one, adjusting the dizzy clockwise tards it, counter clockwise advance it.
tien285
Jul 31, 2009 07:23 AM
irishgod247
Mar 13, 2007 10:35 AM
erikiksaz1
Dec 25, 2004 06:25 PM
