alternator wiring for crx
I don't know why you removed your original question, but here is the answer;
The big white wire goes to the main fuse box on the passenger fender.
The white/yellow wire goes to B5 on the ECU
The white/blue wire goes to one side of the "charge warning light"
The blue wire goes to B14 on the ECU
The black/yellow wire goes to; the other side of the warning light, the main fuse box, and also through a fuse to the ignition switch.
The only reason I know this stuff is that I'm currently re-wiring a 89 to OBD1. All the information is in the factory manual but it can get difficult to locate it. You have to go to the section that covers checking the alternator. The "wiring diagram" in the factory manual is only partial!!
Wes Vann
Wes Vann
InkerB2B
Jul 21, 2008 08:40 PM
