anyone w/ an HF with a ZC swap?
Old Mar 24, 2004 | 12:17 PM
pyro_freak8's Avatar
Default anyone w/ an HF with a ZC swap?
i'm having some spark problems with my ZC swap into my 91 HF....i'll get one spark of i let the car sit for a few minutes then come back and turn the key to the second position...then when i try and start it i get no spark, but fuel is fine.... i think the zc has an si engine harness.....if i switch it out with my hf engine harness will it work? will the hf harness plug onto the engine right? anyone? it seems everyone w/ a zc has an si....
Old Mar 24, 2004 | 01:54 PM
Default Re: anyone w/ an HF with a ZC swap? (pyro_freak8)
ttt
Old Mar 24, 2004 | 02:03 PM
Nocturnal_Lude's Avatar
The HF harness should work, but you may have to add/subtract some wires. I am not 100% on that, but I would stick with the si harness and ecu, as that is the one recomended for the zc if your not actually running a zc harness and ecu
Old Mar 24, 2004 | 02:07 PM
brent_G's Avatar
Default Re: anyone w/ an HF with a ZC swap? (StripShowHatch)
theres the major differnece between the plugs on the dizzzy. Maybe that iwll help
Old Mar 24, 2004 | 02:25 PM
ek_99_SiR's Avatar
Default Re: anyone w/ an HF with a ZC swap? (brent_G)
the hf harness works minus a little rewiring like up here^^^^^ but i have an hf w/ a zc....
Old Mar 24, 2004 | 02:59 PM
Default Re: anyone w/ an HF with a ZC swap? (1.6i-16zc)
which distributor are you using on your zc?
Old Mar 25, 2004 | 07:11 AM
i noticed that in that diagram there are 2 wires on each connector that are different... on the SI connector there are wires #5 and #6(EACV power & Fast idle control valve)...these are not on the HF connector...instead there are #2 and #3(alternator RF signal and EGR lift valve)......what needs to be done with these?
Old Mar 25, 2004 | 12:18 PM
ttt
Old Mar 25, 2004 | 01:30 PM
twin rex's's Avatar
I have a zc in my 90 hf, and I used the hf harness with no problem, just have to make sure to match up all of the right wires. I'm also using my hf distributor and ecu. I have an si ecu but the car won't start with it in(cold) but if i put it in after the car is warmed up its starts fine, I have no idea why so if anyone has a guess please post
ek_b16
Oct 16, 2005 05:47 PM
pyro_freak8
10
Mar 24, 2004 12:10 PM
Sherm
Apr 18, 2003 06:45 PM
pdiddyparsons
Feb 24, 2003 10:33 AM
