size of the brake bleed screw?
Old Mar 24, 2004 | 11:15 AM
noah's Avatar
Default size of the brake bleed screw?
it's CR-V 2001. I guess the brake bleed screw size should be 8, but not sure. Anyone have idea.
And do I need the flare wrench to turn it. Thanks!
Old Mar 24, 2004 | 11:24 AM
MightyMouseTech's Avatar
Default Re: size of the brake bleed screw? (noah)
Are you looking for the size of the thread or the head? Front or rear?
Old Mar 24, 2004 | 11:33 AM
noah's Avatar
Default Re: size of the brake bleed screw? (MightyMouseTech)
the head. Thanks
Old Mar 24, 2004 | 01:27 PM
The fronts are 10mm and the rears are 8mm. And no, you don't need a flare nut wrench. You use a box end wrench which is better than a flare nut in this situation.
Old Mar 24, 2004 | 01:52 PM
noah's Avatar
Thanks a lot!
Junkie
Dec 22, 2007 10:29 PM
Ransom
Apr 17, 2007 04:16 PM
Racermech
Mar 29, 2005 10:24 AM
SlopeSurfer
Jun 28, 2002 07:37 AM
MikeD
Oct 2, 2001 07:07 AM
