Adjust clutch pedal
I'm gonna assume you mean adjust the cable.
Just look pop the hood, follow your clutch cable, where it meets up with the tranny, it will be screwed into an adjuster nut which you can turn by hand. Tighten the nut to make the clutch engage lower (closer to floor), loosent to engage higher.
You shouldnt over tighten or over loosen the cable tho....I.E. the clutch should engage/dissengage around the normal spot.
InJ3cted
May 24, 2005 02:16 PM
