tranny leaking?
Old Mar 24, 2004 | 09:16 AM
vtekthis's Avatar
Default tranny leaking?
my b16 tranny is leaking slowly (dripping) from what it appears to be the drain bolt (that 3/4 rachet head thing) and i tighttended it and it seemed to stop leaking, which it did!! yeah but now it only leaks in my driveway where the car is on a steep angle?? wtf?? any help?
Old Mar 24, 2004 | 10:11 AM
AutoXer's Avatar
Default Re: tranny leaking? (vtekthis)
Have you ever replaced the washer for that bolt? It's a crush washer like the one for your oil drain. It's probably not sealing properly.
Old Mar 24, 2004 | 10:17 AM
vtekthis's Avatar
Default Re: tranny leaking? (EX_AutoXer)
no, i have not replaced it yet, but you thing that would be the reason it would leak on a hil??
Old Mar 24, 2004 | 10:55 AM
scratchy's Avatar
well if it only leaks on a hill check your axle seals
Old Mar 24, 2004 | 11:22 AM
vtekthis's Avatar
Default Re: tranny leaking? (scratchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">well if it only leaks on a hill check your axle seals</TD></TR></TABLE>
how do i check these seals? please explain?
Old Mar 24, 2004 | 06:11 PM
Mike Ockhurts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">
how do i check these seals? please explain? </TD></TR></TABLE>
remove both axles and check the lil rubber piece behind the axles for rips or tears
SonicRacing
Jul 27, 2008 08:07 AM
jasony0630
Mar 18, 2008 11:04 AM
invisible
Mar 11, 2007 09:35 PM
Topdawgg
Sep 6, 2006 06:57 PM
Nyris
17
Oct 11, 2005 11:40 AM
