did search, ....which OEM acura/honda wheels fit crx?
i am sure someone probably has posted this before, but i could'nt find it in a search............basically if anyone has a link to a webpage or something that just shows a chart of all OEM stock acura/honda wheels that fit the crx (88-91) and would even help with pics and what size in inches,
..........i have just had my teardrop 90si wheels so long i am just sick of them, and need a change but i just wanna go OEM and only want about 14" or 15", but i just wanted either a list of all the ones that fit or pics of them so i can decide on something, so if anybody knows anything that would be cool, otherwise i will continue searching on the web.
Well don't know of any link but all Civics and Integra wheels will work as they are all 4x100 bolt pattern
true...... all the honda 4 lug patters are the same except for the accords, and preludes form 92 up..... the civic's will work untill 97? (i'm pretty sure) and of course all the 5 lugs dont fit
but all the older OBD0 cars will work.... even the prelude untill after 1991..... if in doubt... go to the junk yard .... that is how i know.... ask them they know everything if a honda yard.... we got 2 local that between the 2 they have over 3 to 4 thousand car.... only honda! look for your wheels there too.... cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warchild69 »</TD></TR><TR><TD CLASS="quote">true...... all the honda 4 lug patters are the same except for the accords, and preludes form 92 up..... the civic's will work untill 97? </TD></TR></TABLE>
Civic's are still 4x100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceas »</TD></TR><TR><TD CLASS="quote">And some type-R's as well..
ceas..</TD></TR></TABLE>
Nope. Only the 96 ITR had 4 lug non 4x100 but we never had those.
thanks for the replies, i get the idea now on what to look for, ................but still there should be some website with a simple chart showing pics of all honda & acura OEM wheels along with their dimension info and which wheels fit which cars and so on, it would be really helpfull, plus it would be even better with one of those wheel viewers like they have on those tire websites where you can actually see how the wheels look on your car.
tire rack dot com should be able to show you the rims or just look through appearance forum as there are a lot of those "how will my car look on xxx rims?"
You can use almost any FWD honda wheel as all the offsets are within 3 or so of each other so as long as it's anywhere between 40-45 you're fine.
All steelies/hubcaps obviously work
All integra wheels (exc type-R obviously)
Civic SI 99-00 and 02+
All del sol wheels
and so on..
All del sol wheels
and so on..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^jefs0ng »</TD></TR><TR><TD CLASS="quote">
Nope. Only the 96 ITR had 4 lug non 4x100 but we never had those.</TD></TR></TABLE>
jdm 96r was 4x114.3
jdm 96r was 4x114.3
