non oem headgasket question....
Old Mar 24, 2004 | 07:32 AM
danny98r's Avatar
Default non oem headgasket question....
hey guys i just wanted to know some of ur opinions. a year ago my friend drove my car and misshifted and bend some valves. i took it to a trustworthy mechanic and the car was fixed. he checked the engine and replaced 8 exhaust valves. he also replaced many various things( timing belt ,bolts etc) and were all oem parts cuz i saw the packages. wen replacing my headgasket acura did not have one in stock so he put an oem replacement headgasket on my car. the car is running fine. i just want to know if thats going to effect any power gains or compression numbers i had when i had the oem type r headgasket? are they made the same?
Old Mar 24, 2004 | 08:15 AM
ultimatehonda's Avatar
Default Re: non oem headgasket question.... (danny98r)
Its hard to tell if you do not know the brand of the headgasket. If it was a oem replacement it was probably the same thickness and would not affect performance at all.
Old Mar 24, 2004 | 07:23 PM
crazzy's back's Avatar
i think the head gaskets may have a slight difference in thickness.. it might of changed the compression very slightly.. For better or for worse i have no idea...
Old Mar 25, 2004 | 07:17 AM
danny98r's Avatar
Default Re: non oem headgasket question.... (crazzy's back)
so how would i know if im running to the upmost potential of the car? should i bother replacing it.
Old Mar 25, 2004 | 08:05 AM
I think it would be the same if it is a oem replacement. If you go to auto zone and pick up a fuel filter for a honda it looks exactly the same as the oem except its not oem and its the autozone brand which may have been made of different materials. The head gasket should be the same thing.
Old Mar 27, 2004 | 10:16 AM
Default Re: non oem headgasket question.... (ultimatehonda)
see now ur comparing fuel filters something that doesn't make a diifference like a headgasket will.. i think danny is a lil confused i think he meant to say they put in a aftermarket headgasket instead of a oem. cause oem is a factory part..
Old Mar 27, 2004 | 10:32 AM
well a way of knowing is buy checking the compression and match ur numbers with another type-r.. if there pretty much the same then u'll be ok..
Old Mar 27, 2004 | 03:23 PM
non-VTEC's Avatar
the thickness of the OEM gasket to a OEM "replacement" gasket will probably the same. even if there is a slight difference in thickness it will not be noticeable in compression test numbers or compression ratio calculations.
you are worrying to much over nothing........dont sweat it......as long as the car runs good who cares if the gasket is half a **** hair thicker or thinner...
Old Mar 27, 2004 | 04:36 PM
danny98r's Avatar
Default Re: non oem headgasket question.... (non-VTEC)
i ran a 14.2 at 96 with i/h/e so i guess my car is fine. do u think i had a slow trap time with a 2.2 60ft? did i lose in the top end
Old Mar 27, 2004 | 05:13 PM
14.2 is pretty good Did u have any wheel hop?
Old Mar 28, 2004 | 06:26 AM
danny98r's Avatar
on that launch the wheel hop was minor. track didnt feel too good on that day though. launched at 5500
Old Mar 28, 2004 | 09:34 AM
14.4@94 2.05 60ft on my gsr wit i/h/e.
Old Mar 28, 2004 | 01:48 PM
vtec.dc2's Avatar
last time i checked gsr and itr have same headgasket. if they used wrong oem headgakset, you would know by now..
Old Mar 28, 2004 | 02:02 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: non oem headgasket question.... (vtec.dc2)
yeah, the OEM and OE head gaskets all have the same compresed thickness, which I believe is .043 inches or so
Old Mar 28, 2004 | 04:48 PM
danny98r's Avatar
damn crazzy.. thats a good 60 ft. im pretty sure ill do surprising numbers with that 60 ft. wat tires are u using?
Old Apr 1, 2004 | 04:31 PM
bf's at like 16psi.. launched car around 7200rpm.. fun it feels like an awd
ev94eg
Sep 29, 2011 09:24 PM
IBriaIN
Jan 7, 2011 12:22 AM
Krucial_Ek9
Jul 23, 2007 05:48 PM
tegman23
Apr 19, 2007 02:02 PM
