Sunroof
Old Mar 24, 2004 | 06:45 AM
WRTEG's Avatar
Default Sunroof
I have a 94 Ls and the sunroof will only come back a inch and stop, it will open and close, anyone know what this maybe from?
Old Mar 24, 2004 | 07:10 AM
patmcd's Avatar
Default Re: Sunroof (94IntegraNL)
Did you check for debris in the tracks?
Old Mar 24, 2004 | 07:11 AM
WRTEG's Avatar
Default Re: Sunroof (patmcd)
yes, nothing there
Old Mar 24, 2004 | 09:04 AM
gofastgsr's Avatar
My sunroof had difficulty opening and I had it "lubed" by the dealer when it was still under warranty. I think there is a special lubricant for this, not sure? I would call the dealer and they will help you. Then buy the stuff and do it yourself.
Old Mar 24, 2004 | 09:59 AM
Teggsr2120's Avatar
Default Re: (gofastgsr)
Use white lithium grease! It comes in a can with a spray straw and it is made for this kind of stuff. I did it on mine and it worked great...
Old Mar 24, 2004 | 10:52 AM
1hOt95GsR's Avatar
ive also heard that powdered graphite works well for this too...saw it on another thread a while back. and it wont collect dirt and debris like some other lubricants. im not sure where you can get it but if you do a search for sunroof problems or something im sure you can find it.
Old Mar 24, 2004 | 05:25 PM
zuhaetler's Avatar
Default Re: (Teggsr2120)
Don't use white litium grease. It traps dirt and other crap. WD40 the tracks to clean them then apply an Air Tool/Compressor Lubrication Oil.
Old Mar 24, 2004 | 06:17 PM
scorched0's Avatar
Default Re: Sunroof (Hanisbb21)
Powdered graphite or the compressor oil =
And like zuhaetler said, make sure to clean it out good with WD40....
should be able to find everything you need to do this at kragen's or autozone....
Old Mar 26, 2004 | 03:18 AM
WRTEG's Avatar
Default Re: Sunroof (scorched0)
i used the powdered graphite, worked perfect, Thanks.
downest
Welding / Fabrication
21
Apr 11, 2009 10:13 AM
stinkypinky1011
Honda Civic (2001 - 2005)
Jun 25, 2007 05:23 PM
ThaOnlyStunna03
Audio / Security / Video
Jul 30, 2003 03:03 AM
CNSK
Sep 23, 2002 02:57 PM
leesiulung
Aug 15, 2001 03:00 PM
