What can i do to my ls?
Old Oct 22, 2001 | 01:58 PM
integra81's Avatar
New User
Default What can i do to my ls?
what can i do to my ls to make it fast. I have 110k mile on it so i want to get something done so i will get another 110k trouble free miles out of it. I dont want to turbo or supercharge it yet but i am thinking of it. For now i just want an all motor integra that is fast. what can i do to make it quick????
thanks
Old Oct 22, 2001 | 02:23 PM
chuckd05's Avatar
New User
Default Re: What can i do to my ls? (integra81)
a gsr engine with 40k miles, or you can do i/h/e and a nice set up cams with gears and put it on a dyno, with that setup on mine before my turbo i would beat my share of gsr's.
Old Oct 22, 2001 | 02:48 PM
burnsmonkey's Avatar
How much are u lookin to spend? What kinda of power are you lookin for? Any 1/4 mile times you wanna shoot for? Like what goal are you after, more input would help!
Old Oct 22, 2001 | 03:05 PM
RedDawg's Avatar
i'm going with i/h/e, i'm gonna get a better fuel rail and a shot of nitrous until i can save up for a drag III kit.
Old Oct 22, 2001 | 05:17 PM
HKxBlur's Avatar
Default Re: What can i do to my ls? (RedDawg)
I'd be weary of doing anything to add alot of power to a motor with over 100k on it.. Of course, u can, but over time, the rings start to wear a bit, the cylinder walls may have a little scarring, your combustion chamber may have build-up, etc etc..
Basically i'm saying that if u want more than basic bolt-ons, get your motor compression tested/leakdown tested, etc etc to check for any weaknesses where more power may cause premature failure..
Personally I'd sell it, and go buy a GSR that's 2 years younger for $3-4k more.. So u basically have a motor swap with 40-50k less miles on it in a newer chassis.. just a thought..
Old Oct 22, 2001 | 07:42 PM
MRXMUFFIN's Avatar
u have to ask yourself are u going to keep this motor 110k miles is alot. i have 115k on mine and i had to practically rebuild it. there can my a number of things that are going to happen soon to your car. i would suggest dropping in a low mileage GSR engine or if u really want to or dont have the money u can drop in a low mileage LS engine. ive seen LS engines go for under 2000$ i guess they are really unpopular. if u go with keeping it a LS motor is all-motor going to suit u or will FI suit u better. u can do all kinds of things to make it go faster i/h/e cams/cam gears, fuel delivery, higher compression, clutch, wiegh reduction, advance timing, port&polish, NOS, and the list goes on............................ good luck with ur car.
llansy
Apr 7, 2009 10:44 AM
fickel_8
Nov 10, 2006 01:27 PM
phylast
Sep 5, 2004 10:09 AM
pane93civhb
Aug 3, 2004 10:07 AM
skellator_thoj
May 17, 2002 10:30 AM
